Old 09-01-2012, 11:34 AM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Now that I look at the pic on the desktop rather than my iPod, I can see the metal cover. Hopefully it is just a bad connection job. If not, further investigation with the cover removed may be necessary. But removing the cover may void the warrantee. Let us know what happens.
Old 09-01-2012, 12:56 PM   #16
richinny's Avatar
2011 34' Classic
hey twink, would a bad negative wire to the ground (trailer frame) do the same thing?
Ricky
Old 09-01-2012, 01:47 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Yes. Did you find something not making good contact? Was the connection good at the converter?
Old 09-01-2012, 03:52 PM   #18
Splitrock's Avatar
Sioux Falls , South Dakota
Note to self . . . buy a 12 volt jumper test light, a small 12 volt battery charger, a small multi-meter, and a 120 volt no-contact voltage tester.
Old 09-01-2012, 05:19 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The list above is something every trailer owner should carry along with a basic set of tools. Screwdrivers, pliers, wrenches, fuses, electrical tape and the list goes on.
Old 08-19-2013, 10:10 PM   #20
Jesse Lee's Avatar
1974 Argosy 24
Mpls , Minnesota
Well, I do have a conclusion to this post from way back. It was not the connection to the converter or at least I don't believe it was.
I called the dealership that sold the intelepower converter. They tested the converter and it had indeed failed. They issued me a new one and sent my failed converter back to the manufacturer. I installed the new one, being very mindful of not to under or over tighten and all was right with the world, everything electric worked.
Now fast forward to this years camping season.
I fired everything up, everything was working and then, bam, everything went dark again. This time no grounding issue or nothing caused the outage. It just went dark. So, I did what I knew how to do at that point of frustration, I panicked.
I could not understand why this would go out again. I checked every connection. Re tightened and cleaned all my connections to the converter and began to dig for more wire endings. I then noticed one main set of wires going back to the bumper. I went outside to access the bumper hatch and to inspect the 30 amp plug outside. It all seemed fine. Then I saw some strange bolt connected to the outside of the bumper. I pushed on it with my finger and heard a faint snapping sound. I did it again, and to my complete and utter amazement the thing lite up like a Metallica concert! IT WAS A FAULTY BUMPER GROUND the whole time! I was clueless about this wire ending. Never read a stitch about it in the forums. Could not believe I cracked the code and it all had to do with a hidden ground wire in the bumper. Are all Airstreams and Argosy's grounded this way? Pretty cool to discover this on my own. A personal Argosy success story I completely forgot to post and share. Thanks for all the help
Karl (using the account my wife Jess Lee set up for us)
Jesse Lee is offline   Reply With Quote
Old 08-19-2013, 10:51 PM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup chassis ground for 12VDC system.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-19-2013, 10:57 PM   #22
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Main frame ground wire
Below is a photo of the main frame 12 volt ground wire on my 2007 Safari, which is located on the main frame in the front streetside near the spare tire. If you have electrical problems, for example flickering lights, or intermittent electrical problems, you might like to check this ground connection. It sometimes becomes loose or gets corroded. Unscrew the connection and brush the wire until it is shiny and reconnect.
Additional information with another photo of the main frame ground connection:
"Grease is the word"
Name:	DSC_0129 Main frame ground wire.jpg
SilverGate is offline   Reply With Quote
Old 08-20-2013, 07:21 AM   #23
Splitrock's Avatar
Why are there 2 wires? Do they serve different components?
Old 08-21-2013, 12:23 AM   #24
SilverGate's Avatar
2007 23' Safari SE
I'm not sure, but perhaps the second wire is the ground wire from the Ground Buss of my Airstream Factory installed solar power system. Click several times to see an enlargement of this schematic from my Owners Manual.
Old 08-21-2013, 07:17 AM   #25
Splitrock's Avatar
Oh, I see, One is the battery and one is the solar system. Thanks!
