Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-14-2008, 04:02 PM   #1
NewIndianaAS
Profile:  1972 29' Ambassador
Centerville , Indiana
Electric Systems
Having just purchased our 72 Ambassador I am beginning to repair in stages and I have many questions.
1. The plug that goes into your tow vehicle has been cut off and replaced with a flat 4 end. Does this negate the electric brake system on this trailer?
If so, can I still find a manual that will show me the wiring system to replace with the round plug?
2. Is this trailer's lighting system totally 12V and dependent upon a battery being installed to operate?
3. It appears that the only 110 items on it at this time is the a/c and oven.
Is there anything that I am missing?
4. Where do I find an owner's manual for a 72?
5. Where is the closest AS RV dealer for used parts east of Indianapolis towards Ohio?
These are the first of many questions I will have and I do appreciate all of your help. I have replaced the floor in the front and I am currently working on tearing out the floor in the rear bath that has rotted. Any info that I should be aware of?
Thanks again
NewIndianaAS is offline   Reply With Quote
Old 04-14-2008, 04:22 PM   #2
vinstream
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
golden , Colorado
Question 1.... Yes
Question 2.... It is both 12V and 110 depending on what Light
Question 3.... Inverter? Converter?
Question 4.... Don't Have an awnser
Question 5.... Go to Airstream, Inc :: Home
http://www.VinStream.com
"Redesigning Life & Road To Vintage Custom Trailers"
vinstream is offline   Reply With Quote
Old 04-14-2008, 05:09 PM   #3
DEITZ645
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 16
Plug Schematic
NewIndianaAS,
Here is a link to a site that may help you with re-wiring to a 7-way plug...
Marksrv.com 7 way wiring diagram page
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package
1987 34' Excella 1000
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 04-14-2008, 05:12 PM   #4
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
Originally Posted by vinstream
Question 1.... Yes
#2 Should be yes. The 60's had both, but the lights in my 75 are all 12 volt. They run off the battery or from the convertor when plugged into shore power.
#3 Convertor
#4 https://store.airstream.com/product_...products_id=98
Richard
Charter Member Four Corners Unit
Old 04-14-2008, 06:14 PM   #5
NewIndianaAS
Thanks for the replies. Where is the converter/inverter located?
Old 04-14-2008, 06:47 PM   #6
azfiredog300
azfiredog300's Avatar
Profile:  1971 25' Tradewind
Surprise , Arizona
I got my Manual off Ebay.
Jerry C.
"Travelstar Galactica"
WBCCI #13317
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 04-14-2008, 07:30 PM   #7
A/SimpleLife
A/SimpleLife's Avatar
Profile:  1971 29' Ambassador
Sunny South , Florida
On my 71 Ambassador the original Univolt is curbside in the back tucked behind the side of the bathtub accessible through the exterior rear access door.
A/SimpleLife is offline   Reply With Quote
Old 04-17-2008, 01:26 PM   #8
OregonArgy
OregonArgy's Avatar
Profile:  1978 Argosy Minuet 6.0 Metre
Gresham , Oregon
My converter is right next to my battery compartment, under the front gaucho on the roadside. It is plugged into 110 and powers the DC stuff in the trailer when hooked to 110, as well as charges my battery. I bought one of those Intellipowers. I really like it. It's got a 4-stage conversion. I only needed the 45-amp version. For the 110 system to work, though, it has to be plugged into camp power (unless you've got an inverter, too).
3) The Dometic refrigerator might be gas-electric. Mine is, and says so on the front. For mine there is a 110 outlet behind the frig up under the skin when you open the outside panel. I just switch to Electric and it gets started right up.
So...you bought a vintage trailer, did you, honey? Good deal, was it? Oh, just a couple of repairs, huh?
Drat, now our little Argy is starting to grow on me. I guess you were...were...were...right, honey.
OregonArgy is offline   Reply With Quote
Electrical systems ralley Classic Motorhomes 0 02-12-2006 04:38 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Stereo Systems jjonesnc Electrical - Systems, Generators, Batteries & Solar 11 03-17-2004 10:55 AM
Systems Manual Lana 1966 - 1968 Safari 6 01-02-2003 10:28 PM
