Old 10-05-2003, 04:17 PM   #29
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Josh, I screwed up, trying to do forum stuff during commercial breaks during the NASCAR race today. Still not used to the new Airstream website with no GVWR spec. Here's what the load sticker in your trailer should say:
Code:
 6300 GVWR
-5270 Unloaded vehicle weight
- 374 45 gallons water @ 8.3 lbs/gal
-  60 13.3 gallons LP @4.5 lbs/gal
  596 Cargo Carrying Capacity
So you have 596 lbs capacity BESIDES the water and LP!
No, you don't have to carry water when you go to a campground with hookups, but I do. The trailer handles better with it, the diesel doesn't notice the difference, and I won't be stuck with the campground water if it doesn't look/smell good.
Maurice
Old 10-05-2003, 05:17 PM   #30
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Re: Back to weight...
See this post so as to not hijack this thread...
Eric
http://www.airforums.com/forum...5629#post55629
Old 10-05-2003, 05:46 PM   #31
2001 34' Limited
The State of , Ohio
Will do.
Maurice
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Electric/Manual Jack Security Question docbluedevil Jacks, Stabilizers, Lifting and Leveling 1 11-01-2003 11:50 PM
Electric Brake Question 68 Suburban Brakes & Brake Controllers 6 03-04-2003 08:09 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
