Old 12-07-2011, 05:28 PM   #1
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Electric Power Hitch Stopped going up.
On my 2010 25 FB the hitch motor started smoking and struggling to go up. Will go down fine but not up. Smelled strongly of electrical fire. Then I didn't use it for a couple days and it went up but struggled. Now won't respond to going up at all.
Has this helped to anyone? Could there be dirt or grime on the gears? I looked down the top when I had to manually crank it up the rest of the way, and looked underneath,,,,no access I could see at a glance.
Still under warranty....In 2 months no more warranty.
Thanks for the help.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 12-07-2011, 05:59 PM   #2
Vintage Kin
REDNAX's Avatar
Corpus Christi , Texas
That cover will come off somehow. It's a simple enough machine that the problem should be obvious if it was smoking.
2004.0 DODGE 2500 QC/LB Cummins 305/555; 6-manual, 7,400-lbs; fuel cost is 25-cpm towing 34' trailer; 15-cpm solo.
Sold: 1983 Silver Streak 3411 Supreme; 6,860# (8,000 GVWR) Currently: 1976 32' SS
Photos prior to sale
REDNAX is offline   Reply With Quote
Old 12-07-2011, 08:09 PM   #3
Snedwid's Avatar
2010 23' FB Flying Cloud
Perry , Florida
With 2 months left on the warrentee, I would'nt even look at it, as all you can do is void the coverage,,, Run, don't walk to the dealer and let it be his problem,,, just my opinion, others may disagree.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 12-07-2011, 08:23 PM   #4
gainesville , Florida
Go to a dealer!!! jim
WBCCI 3106, AIR 8784, TAC FL 14, 05 Safari 25ft LS FB, 06 Dodge Cummins 3500
zigzagguzzi is offline   Reply With Quote
Worthless Electric at Storage Facility Frank&Mike Winterizing, Storage, Carports & Covers 18 03-09-2012 07:20 AM
Hitch advice - Safari Sport 22 nesvt Hitches, Couplers & Balls 17 12-16-2011 04:50 PM
No LP - All Electric, is it realistic? NickSimcheck Electrical - Systems, Generators, Batteries & Solar 27 08-25-2011 12:18 PM
Electric Power Cord crazeevw Classic Motorhomes 11 08-24-2011 09:42 AM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
