Old 07-05-2016, 11:46 AM   #1
GLB
Electric outlets
I have a2002 Safari 25b. Both outlets in galley above stove and outside outlet do not work. The outside outlet is in general area as the two inside.the lights and all other switches, microwave,range hood all work. The fuses are good. Could all three outlets be dead and need replacing or is there something else I should be checking
GLB is offline   Reply With Quote
Old 07-05-2016, 11:55 AM   #2
richw46's Avatar
Lexington , Kentucky
These outlets are 115 vac. Have you checked the circuit breaker box or is that what you mean when you say 'fuses'?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 07-05-2016, 12:18 PM   #3
GLB
Thanks rich. I just reset the circuit breakers and outlets are working. I feel a little dumb for forgetting about the breaker box under the bed, but appreciate your help on this. Have a great summer
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
warm outlets markus Electrical - Systems, Generators, Batteries & Solar 5 11-29-2003 04:06 PM
Use household 110 Outlets? mcostanzo Electrical - Systems, Generators, Batteries & Solar 5 06-26-2003 10:30 PM
