Old 10-31-2002, 11:04 PM   #1
Joan D'Andrea's Avatar
Send a message via Yahoo to Joan D'Andrea
Angry Electric indicator Panel
Has anyone taken their panel apart. Mine blinks like a neon sign in a storm. Sometimes it's on and sometime's it's not. One minute it says I have 3/4 a tank of fresh water and the next time I have a half tank and then back. The only way to keep the pump button shining is to wedge a toothpick in between the case and the light. I have been hesitant to look inside,but this is gettin rediculous. JLD
Kalakkala II
Joan D'Andrea is offline   Reply With Quote
Old 11-01-2002, 12:03 AM   #2
New Borockton , Alabama
Images: 21
That sounds like a loose, open or shorted wire.
On a different but related note, you can calibrate your holding tank gauges on many models with a small screwdriver. Look for small holes on the face of the panel under the gauges and you should see set screws deep in those holes. Fill the tanks full and turn the screw until it reads exactly full. I know my 76 had this but not positive on the 78. Check the owners manual.
Randy
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
How do I remove the electric reel? k5cad Airstream Motorhome Forums 6 11-26-2003 06:16 PM
Electric Brake Question 68 Suburban Brakes & Brake Controllers 6 03-04-2003 08:09 PM
How can I test my electric brakes? Swingking Brakes & Brake Controllers 7 03-04-2003 06:14 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
