Old 02-09-2018, 04:19 PM   #1
Stevelou
1984 27' Sovereign
1984 27' Airstream 270
Wandi , Western Australia
Electric Horn
I live in Western Australia, own a 310 motorhome. When I press the horn button a small car horn sounds behind the grill. how do I get the top electric horn to work.
stevelou is offline   Reply With Quote
Old 02-10-2018, 07:25 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Greetings Stevelou. I don't know much about Airstream MoHo's, but a buddy had an SOB MoHo once. He had a physical switch on the dash that allowed him to switch between the two.
Maybe somebody who owns an Airstream MoHo will chim in. Good luck!
www.nesa.org
Air No. 6427
Old 11-14-2018, 02:32 AM   #3
310
310's Avatar
Sunshinecity , Horgau
have the same problem
hi,
i have the same problem.
i have found a relay to my right feet, if i sit in my captains chair.
It is working and activates a Air Horn in the front if i push the horn button.
But i cant find the cables they come down from the electric roof horns-color is dark purple and white.
Where do they run in the wall and where do the come out behind Dash? how to activate them?
Please help me!!
Thank you all in advance for helpful tips!
310 is offline   Reply With Quote
Old 11-19-2018, 02:00 AM   #4
310
310's Avatar
help would be great!!
thx
Old 11-19-2018, 06:07 AM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
My '82 310TD has electric horns on top that activate when you press the horn button in the center of the steering wheel. They were toast when I bought the rig and I replaced the horns. They work fine. You can get up there and test to see if you have 12v when the button is depressed. Might want to disconnect the little ones behind the grill.
mayco is offline   Reply With Quote
Old 11-19-2018, 10:29 AM   #6
310
310's Avatar
Thanks Mayco,
I have no power on the roof horn cables.
I found the green cable at the relais gives power when i push the steering wheel knob. And it powers the front air horn.
I disconnected the front air horn. The relais clicks but no power on the roof wires.
I would be happy to know where the cables have their end in the dash area or anywhere there....
Please help me to find their endings....!
Thanks!!!
Old 11-19-2018, 10:35 AM   #7
310
310's Avatar
A wiring plan or description where the cables run from the roof down to where they have their endings, would be the best help...
I have a ˋ85 345....and the cables are black and white, not purple
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 11 11-21-2018 10:34 AM
Horn doesn't work! Astrodokk Classic Motorhomes 9 10-22-2006 07:14 AM
Air Horn repair smily Classic Motorhomes 2 07-28-2005 07:38 AM
Re: Horn 2nd query Orland Dewey General Motorhome Topics 14 07-11-2003 02:19 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
