Old 02-10-2017, 01:29 PM   #1
1967 22' Safari
1977 31' Sovereign
Narvon , Pennsylvania
Electric distribution
Hi there,
Does anybody have or know where to get a diagram of the 12v and 110v circuit boxes? I am changing out and need to know what goes where. I have the trailer electric diagram, just looking for circuit distribution.
If that makes sense
Thanks, Ken
kenwadude is offline   Reply With Quote
Old 02-10-2017, 01:54 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
You might search at https://www.airstream.com/service/manuals/
Enter the year model into the blank box and search for the appropriate Owners Manual.
I think the drawings within the manual will give you the information you are asking for.
Alan
Old 02-10-2017, 10:07 PM   #3
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
What year and model? Usually you can email customer service at the AS factory and they will send you what you want.
Troutboy
Troutboy is offline   Reply With Quote
Old 02-10-2017, 10:14 PM   #4
Boxite's Avatar
2008 22' Sport
Each model of AirStream has an electrical and plumbing schematic which can be downloaded free at the Airstream website.
It's helpful...but it's not a true schematic in the sense that electrical wires cannot be physically located in walls or cabinetry by the diagrams. Plumbing charts are much better however.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 02-12-2017, 05:04 AM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Unless someone has removed the original installation you should find that the fuse box and circuit breaker boxes are labeled. If you are replacing them you can reconnect the same way.
Or are you saying you want to redesign the trailer electrical systems?
sgschwend is offline   Reply With Quote
Old 02-12-2017, 12:25 PM   #6
1967 22' Safari
1977 31' Sovereign
Cushions and platforms
Hi again,
Thanks for your responses. They were great and I was able to find out what I needed.
It is a 67 Safari 22ft twin.
I am doing it the same way, but the circuit boards are toast! No info at all.
So I downloaded the schematic fro AS site!!
Now another question if you don't mind.
Does anybody know the demesions of those "bolster" cushions?
When I bought my unit, it did not have them and have seen discussions about them on this site.
Also, I need to replace the two front couch/bed platforms and it looks like it is 1/2 inch plywood except the last foot of it is 1/4 inch??? In witdh I mean and the side toward the walls. I have plywood in the back of the back cushion for support when it is in couch mode. Not sure what is going on here.
Any insight at all?
Thanks, Ken
Old 02-13-2017, 12:58 AM   #7
Boxite's Avatar
2008 22' Sport
Airstream should be able to supply you with the drawings/dimensions of any cushions.
Rambox
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
weight distribution Craig Hitches, Couplers & Balls 2 04-14-2003 06:57 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 02:48 PM
