Old 09-10-2003, 10:37 PM   #1
1990 32' Excella
jonesboro , Arkansas
elec woes
86 31 sovereign . I have 2 dead outlets. The out side and the one in front under the couch that the univolt plugs in. If anyone has a service manual could you look and see if they are on the same breaker with the lavatory and the kitchen and what order they are in from the back to the front of the trailer?
joel is offline   Reply With Quote
Old 09-11-2003, 05:18 AM   #2
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 121
I had a similar problem on my 72 Overlander. 3 outlets were totally out. Upon further inspection, I discovered that one of the leads on one of the outlets had shook loose. I disconnected the trailer from power, stripped back the wire, reconnected it, and everything was fine. Once in a while there is a simple and FREE solution to a problem. Once in a while.
Barry
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 09-11-2003, 06:49 PM   #3
1990 32' Excella
Cool elec woes are over
Good idea . A wire was loose on the back of the exterior outlet.I installed a new outlet instead of just sticking it back in. Problem cured ! Thanks
Elec. problem again! davidz71 Electrical - Systems, Generators, Batteries & Solar 48 03-13-2005 05:37 PM
Bathroom woes. Theo Waste Systems, Tanks & Totes 20 01-18-2004 02:03 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Dometic woes rdm Refrigerators 4 06-17-2003 06:30 AM
testing the elec brakes? Rog0525 Brakes & Brake Controllers 3 06-11-2002 03:02 PM
