Old 12-19-2018, 09:11 AM   #1
Minneapolis , Minnesota
Easy Start any negatives? Void warranty?
Hey Everyone,
Looking at installing an easy start this Spring. In our 2018 sport16 the AC is really really loud, espcially when the compressor kicks in. I've read that the easy start really helps with compressor noise. Wondering if others have found it helps? Also really like the idea of getting a generator in the future and having the option of running the AC with it.
If these easy starts are so great why don't AC manufacturers build them into the units? Why do they have to be installed secondary? Are there negatives, do they hurt the AC units?
Cheers,
fishbisquit is offline   Reply With Quote
Old 12-19-2018, 09:28 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We (actually, SuEllyn) installed an Easy Start unit just about a year ago. It has worked flawlessly. We have used it extensively. We have over one hundred nights of Airstream camping on it. We have used it on shore power and on our Honda 3000 generator.
As to your question about the warranty, I don't have a clue whether of not the installation of the Easy Start voids the warranty. Our unit was about three years old when we installed the Easy Start, so it didn't matter. My guess would be that Dometic would void the warranty for any alteration done to the unit.
As to why Domectic doesn't build their units with Easy Start from the factory, my guess would be that they would have to raise the price slightly. That would probably be unacceptable as most consumers are pretty stupid and would balk at paying the higher price for the unit.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 12-19-2018, 09:39 AM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
There are no downsides to easy start. Dometic themselves sell an earlier version of a soft starter branded as Dometic.
If there is a failure of the AC, and warrantee is in question, you can simply remove the easy start device and return the AC back to factory, if needed.
wulfraat is offline   Reply With Quote
Old 12-19-2018, 09:46 AM   #4
StPierre's Avatar
1965 22' Safari
Rescue , California
There is a negative to the Easy Start when you use a Honda 2000 , it will not run the compressor at higher elevation. I wish I did more research on this ,as most my camping is above 4000 ft
The St Pierre's
StPierre is offline   Reply With Quote
Old 12-19-2018, 09:52 AM   #5
2019 27' Globetrotter
Salem , Oregon
It looks like your research should of been on generators. From what I understand the newer Honda will work. If not sell it and get a larger unit or another Honda and hook them together.
The Easy Start is a great product but will not cure all ills. Dave
NoResults is offline   Reply With Quote
Old 12-19-2018, 10:20 AM   #6
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Wulfraat is dead on. No worries about easy start.
Old 12-19-2018, 10:23 AM   #7
Wconley's Avatar
2018 28' International
Renton , Washington
I’ve installed them on two A/Cs and have been happy. As for your reason for installing them, there will be a slight reduction in the “thump” you hear when the compressor kicks in. However the volume when running doesn’t change at all. If this is the only reason you have for an Easy Start, I’m not sure I would spend the money.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 12-19-2018, 10:23 AM   #8
2007 22' International CCD
Generator engine power output, no matter what the fuel used, will drop off as altitude increases. As the Overkill Engineering Department Head, I opted for a 3400W Champion Dual Fuel Inverter genset that lives in the truck bed when we travel. It would have to be seriously high altitude to run out of power with that setup, plus an EasyStart installed in the already out of warranty Air Conditioner....
Old 12-19-2018, 11:13 AM   #9
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Many A/S dealers install the easy start (we have two) and it is usually the same dealer that services the dometic warranty. Think about it.
BTW, we had the heat side of one of our A/C's and I thought it would be a simple fix. Nope, the A/C units are not serviceable and they threw away a perfectly good unit and installed a new under my extended warranty. Also, they reinstalled my easy start in the new one at no charge.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 12-20-2018, 09:07 AM   #10
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I had 2 Micro Air Easy Starts installed during my JC warranty visit on my 2017 International. They work great and I can run one off my Eu2000i with not problem. I was told they void the Dometic Warranty but that was not an issue since mine was just about to run out. They do start softer and are quieter when they do.
VaTravelers is offline   Reply With Quote
Old 12-20-2018, 09:23 AM   #11
2017 20' Flying Cloud
austin , Texas
Hi Fishbisquit, when I purchased my then new 2017 20' FC, the A/C was insanely loud (much more so than my 2015 non-ducted International) in addition to the vibration from the floor that I could feel through my shoes. I spoke to the MicroAir folks at the 2018 International rally this past summer and they pretty much said what Wconley already posted. It will help with the initial start but probably not with the noise while running. I'm now on my 3rd new Dometic A/C unit on the FC and (thank goodness) it is not as noisy as the first 2 units but (sadly) still not quieter than the International.
ejami5 is offline   Reply With Quote
Old 12-20-2018, 09:33 AM   #12
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I just had mine installed from AS LA. They stock those items now at their shop.
I've turned it ON using shore power at my house, but everything I've about EasyStart has been positive.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 12-20-2018, 10:07 AM   #13
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
I think that the AC in the 16' Airstream is smaller. It might draw less power.
In my experience, the Easy Start has been fantastic. My 20FC has a replacement AC made by Atwood. It was able to start on a Honda 2000i - the brochure even suggested it - but that was only with the generator's ECO switch turned off.
With the Easy Start, I can run AC easily in ECO mode. I've also used it at elevation without trouble. To me, the most useful feature of the Easy Start is the ability to run the refrigerator, converter and AC all at the same time on household power. That is, with nothing else on the circuit and a 30 to 15 amp adaptor right on the camper's 30 amp power cord. (No extension cords.)
Glenn
Glenn T is offline   Reply With Quote
Old 12-20-2018, 10:46 AM   #14
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
It wonít run it in the flat of Texas either. Need at least the Honda 2200.....at least Iíve read a post that the 2200 is sufficient.
banderabob is offline   Reply With Quote
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
equalizer hitch - any negatives? buffet breez Hitches, Couplers & Balls 126 02-10-2016 09:05 AM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
Basecamp negatives christopher4 Base Camp 15 10-10-2007 12:46 PM
