Old 05-04-2018, 10:27 AM   #1
2015 25' Flying Cloud
Blue Ridge , Georgia
Easy Start 364
Just installed the Micro Air Easy Start on my AC. The pictures and instructions from the Micro Air web site were easy to follow for the Dometic Penguin low profile ac. The AC starts and runs fine on my Honda 2000 with no other load on the generator. Flipped on the refrigerator on electric and the generator red light comes on and interrupts the power which is not surprising. Since I'm putting the Airstream in storage for a month I was wondering what others had experienced as far as how many devices can or can't be run. Appreciate your thoughts.
Gleverett is offline   Reply With Quote
Old 05-04-2018, 10:45 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Did you train the Easy Start on shore power with 5 starts as required? I don't know what AC unit you have but the specs say the Penguin II draws 1700 watts (probably only when it is really hot outside). That alone is probably over the 1600 VA limit for the 2000i. The fridge draws about 300 watts which might well be enough to go over the 1600 watts that puts the 2000i into overload. I'd say you are good, as long as you did the training starts.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 05-04-2018, 11:36 AM   #3
Easy Start
Yes I did the training starts on 30A shorepower prior to trying the generator. Very pleased with the fact I can run the AC on the Honda 2000. Just curious as to others experience. Wonder if the refrigerator run on propane would work with the AC on? Not an electrical wiz am I. Thanks
Old 05-04-2018, 12:07 PM   #4
2011 22' Sport
Portland , Oregon
When the refrigerator is on propane mode it uses zero AC power, as the control circuits are all 12V. If your battery is low then the issue you will face is that the converter, by default, is going to try to charge the battery and that combined with the A/C unit could still overload the generator. Your option there is likely to kill the breaker that feeds the converter AC power.
SilverHouseDreams is offline   Reply With Quote
Old 08-13-2018, 06:37 PM   #5
StPierre's Avatar
1965 22' Safari
Rescue , California
Easy start problem ? I installed a new Brisk Air II 13500 btu with a Easy start , I also have a two year old Honda 2000. On our first trip without hookups the a/c would start but the compressor would drop out after a couple of minutes. We tried three different Honda 2000 generators ,that other campers had ,same results. The only way it worked is if we linked two together. Has anyone had this problem ? I did turn off all other power sources. Thanks for the help
The St Pierre's
StPierre is offline   Reply With Quote
Old 08-21-2018, 01:56 PM   #6
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
What elevation were you at? Above 5,000 feet, generator power loss won't allow my Easy Start/13.5 AC to run. Last week I was at the Salt Flats in Utah, 4200 foot elevation. Compressor would start, then stall. If left alone, it did cycle like that all night and got us cool. In the heat of the day, it would not even cycle. Generators lose 2-3 percent power per 1000 feet of elevation, so 8-10% (at 4,000 feet) just couldn't get me there with the eu2000i.
pcskier is offline   Reply With Quote
Old 08-21-2018, 02:37 PM   #7
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I just had two Easy Starts installed by JC on my 2017 International. I believe the factory A/C units are 15,000 and 13,500 BTU units. I did the 5 training runs on shore power and just today was able to do some testing with my Honda eu2000I generator. I have two that I purchased from Genconnex already converted to propane. The results of my test. I was easily able to run either A/C unit plus all the lights in the trailer without issue. I had my refer on propane so I need to run a test with it on electric power to see how that impacts the generator. When I used both generators I am able to easily run both A/C units and all the lights or 1 A/C unit and the microwave and all the lights. I was a little concerned initially because I know you lose about 10% due to the propane conversion. But there was not issue with running them. I ran them for several hours without issue. Very pleased!
VaTravelers is offline   Reply With Quote
Old 09-18-2018, 11:58 AM   #8
2016 30' Flying Cloud
Wylie , Texas
Who is JC and how do I hire JC?
Who is JC and how do I get JC to install easystart on my Flying Cloud?
jakeloy is offline   Reply With Quote
Old 09-18-2018, 12:41 PM   #9
pcskier's Avatar
Park City , Utah
JC is Jackson Center, Ohio...the factory. Any semi-competent Rv tech or electrician can install an Easy Start for you if you aren't comfortable doing so.
Old 09-26-2018, 09:38 AM   #10
2007 27' International CCD FB
San Diego , California
A single eu2000i should run an A/C with easy start just fine. There won't be much margin for anything else though. It's amazing it's even possible, as prior to the easy start, it required two eu2000s in parallel!
If you want more power margin for elevation or extraneous devices, consider selling the eu2000 for a new eu2200. More power on account of its 20% larger engine and beefed up inverter. Same overall size. The eu2000 easily sells for $700 on the open market, eg craigslist. New can be had for $999. I sold two old ones for 1 new.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 09-26-2018, 01:18 PM   #11
2010 27' FB Classic
N/A , Texas
I asked JC to hook up my easy start unit last year and the said they don't install them. Glad to see they installed yours and that the easystarts work well. Could you provide me with the name of the installer at JC so I can speak to that person myself before driving there? The service advisors are not all on the same page concerning the install.
Old 09-26-2018, 01:36 PM   #12
Long Island , New York
Thumbs up
That's the ticket!
Old 09-26-2018, 02:16 PM   #13
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Agree; why drive from Texas to JC if you don't have to? There are closer options...most AS dealers now have done this installation, if you talk with a manager in service. I also found the 2200 converted to propane by Genconnex, to be quite capable of starting/running my 13,500AC at 6000+ feet this summer while in Banff, with no modifications to my unit....I don't have this unit; it was a friends and he does have the Easystart installed on his 23D, but it worked during our trial on my AC...looking for more data on this one. I use a Champion Dual Fuel which works fine without Easystart on either AC..just 95lbs is all.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 09-26-2018, 05:22 PM   #14
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I found that the Hutch Mountain propane conversion for 2000i and 2200i are very good. Duel fuel with very little loss of power on propane.
https://hutchmountain.com/products.h...131/category=0
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Support Airstream Forum***
turk123 is offline   Reply With Quote
Micro-Air EasyStart 364 Soft Starter Micro-Air Airstream Classifieds 3 08-10-2018 06:03 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
