Old 09-19-2014, 08:49 AM   #1
Sewickley , Pennsylvania
Duo-Therm AC/heat pump mod 630515
It appears my Duo-Therm AC/heat pump mod 630515 has lost its refrigerant charge. Is it possible to recharge the system? If not is the only option to replace the unit?
THX in advance for your help.
castingabout is offline   Reply With Quote
Old 09-19-2014, 08:57 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Re-charging is NOT possible in it's present form, as the unit was hermetically sealed at the factory after the refrigerant charge was applied. If you can find that special HVAC tech who will take on the job, it can be done, but generally only after you remove the unit from the roof.
Thee are special Schrader valve fittings that can be soldered into the ends of the existing tubing (hi and low sides) that were crimped and solder filled and when properly done, will hold the charge. The problem is finding the reason that you lost the initial charge. Locating a leak and repairing that is generally time consuming and costly.
I had it done to a unit where the owner had pierced one of the tubes at the end of the evaporator. It was in an accessible location, and the HVAC tech repaired the hole, added the Schrader fittings as described above, re-charged the unit and it is still working today.
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Duo-Therm Heat Pump mocus Electrical - Systems, Generators, Batteries & Solar 11 11-27-2013 08:47 AM
Duo-Therm Heat Pump/AC myrnaw Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-12-2011 09:46 AM
Dometic Duo-Therm "Cool Cat" heat pump/AC unit?? PA BAMBI II Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-19-2010 08:52 PM
Duo-Therm Heat Pump Gael79 Furnaces, Heaters, Fireplaces & Air Conditioning 8 04-23-2010 09:32 PM
