Old 07-17-2019, 11:15 AM   #1
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Duh Moment with 30 Amp Service
This could easily go under the air conditioner topic too.
I recently noticed that my breaker was flipping in the summer heat far more than usually happened. Anything in addition to the air conditioner and the refrigerator running and POP. I speculated that the park had low voltage for a few minutes... then oh duh! My upgrade from a 13.5K air conditioner to a 15K unit! Well, of course it draws more juice. So, water heater is now on gas only and every morning when I get up I was switching the fridge to gas also. Then, in a flash of semi-intelligent thought, i simply used a heavy duty extension cord and plugged the fridge into the 20 amp on the post. I still turn the water heater off over night just to save propane. And I can still get very warm water in the morning. Once I flip the gas on, it gets hot by the time I've brushed my teeth. With these simple precautions I can also run an induction burner OR the microwave.
50 AMP service might be nice, but it is really NOT a major hardship to live with 30 even with a bigger A/C. In this weather, if I get the yen to make 5 lbs of potato salad and 4 dozen hotdogs, I would rather do that outside in a dutch oven or grill. It is camping after all.
Old 07-17-2019, 11:26 AM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Install a MicroAir EasySTART to reduce the startup load.
Funny thing though. My 15K does not draw anymore amps than the 13.5K did. The only difference between the two units is the size of the condenser coil. 13.5k has 2 layers and the 15K has 3 layers.
Old 07-17-2019, 11:32 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Smart simple power mod.
I did something similar to power one of those what are they ceramic space heaters. Easy peasy.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
West A “duh” moment McDave Boondocking 5 08-13-2018 08:09 PM
Duh! Tent stakes and cord! lsbrodsky On The Road... 4 03-24-2014 11:01 AM
Duh....I forgot how mandolindave Photography 9 03-06-2013 07:49 AM
flat front access panel - duh! JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 03-04-2013 05:08 AM
Duh! How do I search? doctormark Forum Admin, News and Member Account Info 5 07-17-2009 10:16 PM
