Old 04-02-2006, 05:21 PM   #1
casarodante's Avatar
2012 31' Classic
Drilling fiberglass for cable run
In the process of putting a flat panel TV in the rear bedroom, I have to get the coax cable back there from where the original is in the front. In my plan I will be going through the middle bathroom. This will require drilling through some fiberglass panels, etc. I need some guidance on drilling through the 14 year old fiberglass. Fast or slow? Small pilot hole then progressively larger? Put down tape to help any shattering? Questions like that.
Thanks!
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 04-02-2006, 05:29 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
How big a hole are you planning on drilling?
Small a standard drill bit will work fine.
Tape is recommended to reduce splitering. Go slow, gentle pressure.
You can start with a small hole is you wish and go bigger.
Run the cable without the connector on the end and you can get a single wire through a 1/4 inch hole.
Michelle TAC MT-0
Sarah, Snowball
Pets in the motorhome eraffety The Pet Forum 32 03-26-2007 08:04 AM
Shakedown Run keylime 1959-69 Tradewind 5 12-05-2002 12:35 PM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Sink and Shower restoration Bennie Sinks, Showers & Toilets 30 11-02-2002 01:14 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
