Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-02-2006, 06:21 PM   #1
caadoptees
caadoptees's Avatar
Profile:  1992 25' Excella
Visalia , California
Images: 16
Drilling fiberglass for cable run
In the process of putting a flat panel TV in the rear bedroom, I have to get the coax cable back there from where the original is in the front. In my plan I will be going through the middle bathroom. This will require drilling through some fiberglass panels, etc. I need some guidance on drilling through the 14 year old fiberglass. Fast or slow? Small pilot hole then progressively larger? Put down tape to help any shattering? Questions like that.
Thanks!
Roger & Roxie Smith (WBCCI#27380 - Air#178)
Visalia, CA (between Fresno & Bakersfield)
1992 25' Excella - Nuestra casa rodante
2003 F-250 6.0 Turbo Diesel Crew Cab
http://www.casarodante.org
caadoptees is offline   Reply With Quote
Old 04-02-2006, 06:29 PM   #2
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
How big a hole are you planning on drilling?
Small a standard drill bit will work fine.
Tape is recommended to reduce splitering. Go slow, gentle pressure.
You can start with a small hole is you wish and go bigger.
Run the cable without the connector on the end and you can get a single wire through a 1/4 inch hole.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Pets in the motorhome eraffety The Pet Forum 32 03-26-2007 09:04 AM
Shakedown Run keylime 1959-69 Tradewind 5 12-05-2002 01:35 PM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 08:40 AM
Sink and Shower restoration Bennie Sinks, Showers & Toilets 30 11-02-2002 02:14 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 04:02 PM
test
