Old 08-21-2006, 07:58 AM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Double down ground...
So I get home from the amazing Region One Rally and find my 3 way fridge off.. On the way home we stopped at a farm stand and bought some steaks and stuff. When putting them in the fridge I found a flashing displace meaning no fuel. OK, just set it for DC. Check the TriMeteric and I'm only down 4 amps with the truck running.
Get home an the unit was dead. Free thought was of course panic. Did something really bad, fuse?, breaker, !!!!! control panel in unit. Looked in back of fridge an found the ground wire came off. Relief. Joy. Put it back on and the unit is still dead. Get out the meter, no 12 volt behind the unit. Panic again. I thought maybe I fryed the self resetting breaker. Checked the front panel where the 12 volt all ties together, battery, TV, fridge. Found the #8 ground to the fridge was off. Came right out of the lug.
Lesson. Just because you found one bad ground doesn't mean there isn't another. Check the simple stuff first.
Over59 is offline   Reply With Quote
Old 08-21-2006, 09:01 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
good deal that you found the problems.
never assume anything works when troubleshooting electrical items. check from the source to the load. positive and negative, hot and neutral if it is a ac circuit.
john
you call them ferrets, i call them weasels.
Old 08-21-2006, 09:15 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by Over59
So I get home from the amazing Region One Rally ...
Yippee, hijacking time!!!
Sooo, Region One Rally? By golly, pretty soon you're going to reveal waaaaayy to much and the rest of us might get an idea what state you live in.
and a gratuitous thbbbttttt to all you other folks who don't at least allow your state (or "fulltiming" for the gypsies) to show up in the little doodad square to the left of posts...just one vote, here OK, erecting the force field shield, here
Converting twin beds to one queen... TinRoof General Interior Topics 16 09-18-2016 12:01 PM
Coast To Coast Rv Resorts ALANSD On The Road... 30 09-07-2011 09:40 AM
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
Next Classic Airstream Motorhome Rally winner WBCCI Rallies & Events 38 04-24-2002 11:22 AM
