Old 01-19-2014, 05:30 PM   #1
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Doorbell
OK OK I know... who the heck needs a door bell on an Airstream!
My Excella has one however the button is beginning to fail. Anyone have a source for the original button? Mine is the one built into the handle/deadbolt/doorbell casting.
Ideally I'd love one to fit that also had an led (I'm a Clark griswold type).
AtomicNo13 is online now   Reply With Quote
Old 01-19-2014, 05:52 PM   #2
1974 Argosy 20
Kooskia , Idaho
Self answering question: who the heck needs a door bell on an Airstream!
But I did have one on my 310 motorhome. In 10 years no one ever used it, not once.
Since it is a 12 volt DC system, not 16 volt home AC bell system, it would take a special DC lighted doorbell button, and I kinda doubt you will find one. Even an original black one may be hard to locate.
Old 01-19-2014, 05:59 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Since it is there.... I want to keep it working! People use mine all the time! Fwiw the hardware store doorbells work just fine with 12v!
Old 01-19-2014, 06:49 PM   #4
Most any hardware store or Home Depot has the door bell button.
!2 volts DC is the same as 19 volts effective AC voltage.
12 volt DC motors work exactly the same on 19 volts or there about AC.
Old 01-19-2014, 07:18 PM   #5
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
While we are on the subject, how about a replacement for the rest if the doorbell-- the unit inside? I need a replacement door bell-- not the button. where can I get that? Will a Home Depot one work? -Katie
Skatiero is offline   Reply With Quote
Old 01-19-2014, 07:53 PM   #6
dznf0g's Avatar
Oswego , Illinois
Most of the home ones are AC powered with a 16V transformer. Maybe there are some battery ones out there, but that is what you need......or a 12V one hard wired to your coach batteries. OEM is 4 D cells, IIRC.
-Rich-
Old 01-19-2014, 08:09 PM   #7
A regular 24 volt AC door bell will work just fine on 12 volts DC.
The original bell that Airstream used was for 24 volts AC.
Old 01-19-2014, 09:03 PM   #8
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
The OEM one in both of our Airstreams are 12 volt and hard wired to the coach batteries. Hmm, I guess a house one won't work, then? I guess I'd better see who sells a 12 volt one! Katie
Old 01-19-2014, 10:04 PM   #9
1974 Argosy 20
Kooskia , Idaho
It was the OP's desire to use a LED lighted button which I was referring to. The normal lighted button has a small very long life incandescent light in it and would work fine on AC or DC. But when you go to an LED light some internal circuitry has to be involved to get the right power to any LED used. Since home doorbells use 16 volts AC any LED lighted doorbell button designed for that power source probably would not work on the 12 volts DC of the Airstream doorbell circuit. And an incandescent lighted doorbell button would become a bad constant power leak on the batteries anytime the rig was not plugged in.
I have not seen any LED lighted doorbell buttons, but there may be some out there.
Old 01-19-2014, 10:50 PM   #10
richinny's Avatar
2011 34' Classic
as fir the bell, i added a 12v buzzer (radio shack) to the rear bedroom because you can barely hear the bell over the air conditioner or television. why they use a battery bell when 12v is available is beyond me. the buzzer is nice and small and loud enough to hear over the air conditioner. i wired it to the existing 4 d cell bell.
Ricky
Old 01-19-2014, 11:56 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I used a $9 replacement ding dong unit from Lowes. It is identical to the OEM unit that pooped out in my unit. Some have referenced battery powered bells? Not mine
... 12 volt coach powered..
As far as the button goes, I have tried the available replacements and all are the wrong size... too big or too small. I just know there is the perfect one lurking with an Excella blue led!
Old 01-20-2014, 04:25 AM   #12
sandlapper's Avatar
1993 34' Excella
York , South Carolina
I replaced our button with one from Lowes. It is not black, like the original, but is lighted. Just popped the pooped one out, hooked up the new one, pushed it back in for a perfect fit.
As for using it, only Classic owners know it is there and use it. Still, we love it.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-21-2014, 04:13 PM   #13
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Great info, thanks!
Old 02-01-2014, 07:41 AM   #14
1986 27' Sovereign
Nixa , Missouri
Images: 21
Anybody have a pic of what the button looks like? Mine is missing from the hole. I asked the PO when I bought what the box on the wall underneath the table was and he had no idea after owning it or 15 years. When I removed the box recently to pull the wall panel I got a ding dong sound and then I knew. I would like to get a button back in there and use. I may check with Colaw RV salvage as they are just an hour down the road.
Barry
bweldon is offline   Reply With Quote
