Old 09-13-2017, 04:09 PM   #1
2015 25' FB International
Peace River , Alberta
Dometic Fridge
Hello Everyone,
Some back story. Plugged the trailer into 240V by accident last month.
I replaced the converter with a Parallax RU55. Had quite a time getting the old one out. The little hex screws must have been torqued in by a gorilla. Striped one so bad I needed vice grips to get it out.
Seems to be working perfectly. Though the front plate doesn't line up quite perfectly. Will be getting back in touch with Parallax.
Anyway, the new issue is that I am pretty sure that I blew out the refrigerator control board. Luckily, that is the only thing that seems to not be working.
I am trying to find a replacement, but am unable to find the anyone offering the actual control board with the same number. Does it have to be the exact match?
Anyone have the same problem?
Kalidas is offline   Reply With Quote
Old 09-13-2017, 04:22 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I replaced the control board for my Dometic A/C unit this summer. The PN was not the same, but I could see that all of the components and shape of the board were the same. I got it and it worked. Ask the supplier to send you a high resolution electronic photo so that you can compare the board he has to your board. Good luck.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 09-13-2017, 05:16 PM   #3
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Dometic changes their part numbers constantly, so don't worry about that, just get the board that matches your connector setup, thats all.
vintagemotor is offline   Reply With Quote
Repaired Fridge Scoop and Fridge insides robwok Refrigerators 8 08-27-2015 08:00 AM
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
