Old 03-24-2018, 03:35 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Dometic Comfort Control Center 2 issue
Curious if anyone has had an idea issue with no furnace power? Everything works but the thermostat won't sent power to the furnace. I've tried everything, reset, fuses, etc. no power is sent to the furnace.
Ted S. is offline   Reply With Quote
Old 03-26-2018, 01:27 PM   #2
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
Newb here with a FC25FB2018...Well, keep an open mind for the simple things Iíd urge. Then resort to the experts
-Got propane?
-Propane flowing?
-Using the right control?....if Iím not using the correct controller ie unit one not unit 2 or whatever I wonít get it going..
-I understand the furnace fan is a real juice hog make sure itís on shore power.
-Make sure you manually flip the fuses to the trip position then back in case you get a sneaky trip where visually it isnít obvious
-look into the furnace compartment outside... see a flame? See anything obviously amiss etc
-open up access to see the furnace inside if ya can, just some screws usually, visually check wires never know what mightíve been left unfinished in the build refurb etc
Good luck!
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Atwood Furnace & DuoTherm Comfort Control issue Daniel LOUIS Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-30-2017 04:43 PM
Dometic Comfort Control Center 2 Thermostat dave_oleary Electrical - Systems, Generators, Batteries & Solar 13 09-27-2014 05:32 AM
Dometic Comfort Control Center Codes fmr.capt.evi Furnaces, Heaters, Fireplaces & Air Conditioning 41 10-21-2012 06:56 AM
Comfort Control Center Behind TV ?? Ag&Au Electrical - Systems, Generators, Batteries & Solar 3 09-18-2009 05:03 PM
Comfort Control Center jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-15-2003 02:19 PM
