Old 07-20-2015, 01:42 PM   #1
LisaB2595's Avatar
Katy , Texas
Dometic AC sensor issues?
We've had our new unit out twice and so I have small sample size, but am looking for help. I don't get an error message but I had an AC unit question - I have a brand, new 2015 Flying Cloud with two Dometic units. I set the thermostat to Cool with auto fan in Zone 2 (common area) fairly high (about 83) I do the same with Zone 1 (the bedroom). Zone 1 shuts off at the desired temperature, and when you push the inside temp number it's right around the zone setting. Even when you feel the air trhoughout is nice and cool Zone 2 can run on and on. The inside temperature at one point said 91 - and I know it wasn't close to that warm, so I wondered if the temperature sensor was in a place where it was affected by the outside. Does anyone know where the sensors are to measure the inside temp? Thanks.
LisaB2595 is offline   Reply With Quote
Low Coolant Sensor guy99 General Motorhome Topics 27 10-14-2013 10:47 AM
Cleaning the Waste Tanks / Fixing Sensor Issues Re-Pete Waste Systems, Tanks & Totes 13 09-28-2012 09:27 PM
Oil pressure sensor on 454?? WYScott Mechanics Corner - Engines, Transmission & More... 15 10-09-2005 09:21 AM
Where is the Speed Sensor? (Allison Tranny Error) Griffin Mechanics Corner - Engines, Transmission & More... 4 12-16-2003 04:57 PM
gas tank sensor wb13798 Mechanics Corner - Engines, Transmission & More... 21 08-21-2003 06:04 PM
