Old 07-01-2019, 08:46 AM   #1
@steadystreamincashios
Zcashio's Avatar
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs , Arkansas
DOMETIC 3-way fridge help- RM8501
So, this is my first time having a 3 way fridge. I’ve got propane lines working and it works on 120V while hooked up to shore power. Only issue i am having is determining how to make it work on 12V while hooked to the tow vehicle. I have all my 7 pin wires wired correctly, as I found a diagram of the late 70s wiring color codes and I now have “trailer brake connected” symbol on vehicle dash, reverse lights are working, and so the charge line is now wired correctly. What am I missing here? I read where the D+ on the back needs to be wired but a Dometic rep through email told me that is only for a motorhome installation.. is that correct?
Any help would be appreciated as to how I can get this working. I’m not opposed to running fridge on propane while driving, but I want to be able to run on 12V when I want.
Thanks.
Zcashio is offline   Reply With Quote
Dometic RM8501 tracenuttall Refrigerators 12 10-06-2014 08:42 AM
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Dometic 2 Way Fridge snakecharmer Airstream Classifieds 0 01-08-2014 02:11 PM
2-way vs. 3-way Dometic loriday Refrigerators 12 08-15-2010 09:21 PM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
