Old 10-14-2015, 09:25 AM   #1
2012 30' International
Key Largo , Florida
Domestic A/C,heat control box
We arrived home yesterday after a long trip and hooked up our 2012 International 30 to our 50amp shore power to prepare for clean up. The A/C (both units ran and brought the temperature to the set 78 degrees. We left the trailer overnight and I noticed by late morning with the outside temperature reaching 85 deg that the A/C had not started. I looked at the domestic control and it is dead and does not respond to any attempts to light up/display. The light which I believe to be on the same circuit as the control box (bedroom/shower lights) all work fine. Any suggestions for further checking?
Martin R is offline   Reply With Quote
Old 10-15-2015, 06:04 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Last year I had a similar issue. One of the 12v breakers had tripped.
I suggest you should check continuity of the 12v fuses/breakers. If they are good, check the 12 power supply wire and ground wire at each roof top unit.
Alan
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
