Old 07-18-2011, 01:50 PM   #1
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Doh, Only two wires but the fan runs backwards!
I have a simple toggle switch which was wired in to the back bedroom to run two 12v fans and I just cannot get them to push air out rather than suck it in.... yes, I've switched the wires to the other switch post but there is not change. Now, I'm usually ok with wiring but this is SO simple I can't figure it out. Any comments (good or bad) will be accepted and taken with good humor.
GREENovaters is offline   Reply With Quote
Old 07-18-2011, 01:53 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Permanent magnet motors will reverse if polarity is reversed (exchange wires going into motor). If the fans are computer type, they're brushless DC motors and cannot generally be reversed unless designed for that.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-18-2011, 01:55 PM   #3
Registered User
1995 36' Classic 36
Images: 14
So what you are saying is that, regardless of what I do now, those fans are always going to run backwards?
Old 07-18-2011, 01:58 PM   #4
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Can you turn the fans around?
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 07-18-2011, 02:25 PM   #5
Registered User
1995 36' Classic 36
Images: 14
Cheap $20 fans
- Bart
Bart, they're cheap plastic fans. Any suggestions or did you basically state that they're somehow reversed forever.....
Old 07-18-2011, 02:29 PM   #6
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
See this URL it's not that hard.
HOW TO: Wire a DPDT rocker switch for reversing polarity
Damon
damonbeals is offline   Reply With Quote
Old 07-18-2011, 02:57 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
If you have a standard automotive type install the motors are grounded as the return to the battery - so flipping the wires on the motor itself might work... If they are muffin fans, it will have rotation and airflow directions indicated usually by universal language symbols... ←↓ or →↑ etc. (nearly invisible) cast into the plastic housings.
Old 07-18-2011, 03:05 PM   #8
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
you need to return those fans and get some set up for the northern hemispshere. Somewhere in South Africa or Brazil there is a guy with the same complaint....
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 07-18-2011, 04:12 PM   #9
Maniacal Engineer
barts's Avatar
What kind of fans are these (a picture would help here)?
- Bart
Bart Smaalders
Menlo Park, CA
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 09:21 AM
AC Fan Motor Seized? jonny Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 02:00 PM
Fried trailer wires Monicaro Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 04:08 PM
Fan Motor Okiegent Roof Vents, Skylights & Fans 19 05-15-2011 11:58 AM
1960 wall wires blue black red white Lothlorian Lights - Interior & Exterior 2 04-02-2011 02:03 PM
