04-08-2013, 01:01 AM
South
, Mississippi
Does this breaker box need to be rewired?
Attaching multiple photos to show you what I've got....
Started another thread attempting to figure out how to find a Hubbell "Twist-Lock" plug for my inlet. Fairly sure it's a non-NEMA plug. If I had to bet, I'd guess that the matching plug for the inlet is a Hubbell 3333c, for which you can see images here. The middle prong on my inlet is a "plunger", so I think it's actually a dummy.
Anyway, about the breaker.... it says it's rated for 125 max amps!!! Something else about this trailer [which is an Avalair -- off shoot cross between Avion & Airstream, BTW] is that it has a "secondary junction" box w/ 15 amp wire & adapter on the outside next to the twist lock inlet. Sooo... I'm really not quite too sure about how to wire a breaker box, but it appears to me that the black cable is the secondary junction box from outside. The yellow cable is the 30-amp inlet, but it appears that all its wires go to the ground bars... altho, now that I'm thinking about it... one of these bars is likely ground, and the other is a "hot bar". I'm only acting like I know what I'm talking about here. I'm guessing that the green & white wires are the hot wires, and the black wire is the ground wire. Just a guess....
Hopefully the pictures look clear enough.
04-08-2013, 05:22 AM
1995 30' Excella
Bowie
, Maryland
The one thing that jumps out at me is: What's that black wire that goes straight to the bus bar, sans breaker, in the second picture? Presumably that's the incoming power, but you'd want that on a breaker, too.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
04-08-2013, 05:43 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Get someone that KNOWS what they are doing.
I see multiple code violations in those pictures.
FWIW Black is the Hot feed, White is the neutral and green is the ground.
Yes the box needs to be rewired.
Aaron
WBCCI #XXXX AIR #2495
04-08-2013, 07:30 AM
Naples
Accident waiting to happen!
Sorry, but that has to be one of the WORST wiring jobs I have seen. Re-wire............ ABSOLUTELY!
Start with separating the neutrals and grounds into separate bus bars. Add strain relief to the incoming wires at the case openings. No input breaker. No visible chassis ground ( since there is no ground bus bar). Clean up all of the wiring so it enters the breakers or bus bars at right angles.
And that's just for starters!
YES! Definitely get someone (NOT an amateur) who really knows how to wire an RV-specific breaker box.
lewster
04-08-2013, 08:52 AM
1968 24' Tradewind
Oxford,
, Mississippi
You might take a look at this from VTS to replace the plug:
Furrion 30A Round Stainless Inlet
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
04-08-2013, 09:31 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Lewster
I was wondering if the grounds and neutrals needed to be separated. Is an input breaker required? Could you please tell me where I can get an RV specific breaker box? I don't need one with the 12v stuff as my 12v box is on the other side of the trailer.
Thanks in advance, Dan
04-08-2013, 10:23 AM
South
, Mississippi
So you're suggesting the breaker box needs to be replaced??
I texted these photos to a professional yesterday, and he quoted me $225 for "rewiring the power supply and bringing it up to date", and that even includes the Hubbell plug w/ wire that I need. Seems like a fairly good deal, but I'm not exactly sure what he means by "rewiring the power supply and bringing it up to date".
04-08-2013, 10:24 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
All things considered, a new properly sized circuit breaker box with new breakers would be the best solution and they are relatively inexpensive at the likes of Home Depot and Lowe's.
Also, any circuits around water - kitchen, bathrooms and outside - require GFI (ground fault interrupter) breakers which are more expensive than regular breakers. That is a requirement of the NEC (National Electrical Code) since the early 70s.
04-08-2013, 12:10 PM
Wise Elder
2010 30' Classic
South of the river
It's clear that someone left you a mess.
Sorry, but that has to be one of the WORST wiring jobs I have seen. Re-wire............ABSOLUTELY!
I've seen worse, but only in buildings originally wired when REA came through.
There is a ground terminal in the bottom center but it isn't large enough. He will have to add a ground bar. Usually it's workable to adapt whatever ones are readily available though it will take some drilling.
+1
Originally Posted by 68 TWind
As has been pointed out to you before, you should remove the obsolete inlet and throw it away. If you don't want to spend the money on a new inlet then just use a 30a cord, permanently installed.
Yes
Not if there are 6 or fewer breakers and the shore power cord is sized to match the plug with which it terminates
Airstream used an ordinary Square D QO load center in my trailer. They work fine. Any breaker box can be used as long as it has a ground bar that is separate from the neutral bar. For many breaker boxes, the ground bar can be purchased separately.
Nothing wrong with the box itself, but the wiring is terrible.
Either his rates are incredibly reasonable or he has no idea what he's getting into and will change the price once he figures that out.
Again, throw away the inlet you have, even if he has a matching end in his junk drawer you'll be up a creek if something happens to it while you're on the road. You can buy 30a Marinco cables anywhere.
04-08-2013, 08:20 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Jammer
Thanks for answering my questions. I was hoping that you or Lewster would step in and clear it up for me.
I have looked at the Square D panel boxes at Lowes. I just don't like the size. They are 12.5" long by 9" wide and will hold 6 breakers. I will probably try to work with the original panel box. It has a 30 amp main circuit breaker with two 20 amp circuit breakers and is much smaller.
Dan
10-26-2021, 05:17 AM
1966 17' Caravel
Riverview
I know this is an old post but what did you end up doing?
Jammer
Dan
10-26-2021, 05:25 AM
1967 26' Overlander
Huntsville
, Alabama
LaurieB - there is a good chance your Caravel has the same box as my Overlander. "New Old Stock" breakers were available on eBay a few years when my Airstream's AC breaker wore out.
Hope this helps,
Tom
11-14-2021, 09:32 AM
1987 34' Limited
Hantsport
, NS
Aaron
Inspiration!
