Old 08-17-2007, 01:22 PM   #1
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
Does anyone know what these are?
Picture 1 is of some sort of wire box that is located on the wall above the battery compartment. It has 2 wires going into the wall. Picture 2 is a switch located below the fan battery power and city power what does this switch control? Picture 3 is either looks like a junction box or light switch, outlet? it is located in the overhead cabinet above the kithen sink. Picture 4 is some thin wire hanging down from the ceiling which is in the front closet of the bedroom it has 2 wires. Picture 5 is another box like picture 3 which is in the back closet of the bedroom. Thanks for your help, 1963tradewin
ID:	43406   Click image for larger version
ID:	43408   Click image for larger version
1963tradewin is offline   Reply With Quote
Old 08-17-2007, 01:57 PM   #2
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Your 1963 Tradewind has two separate electrical systems, one that is 12 volts direct current (DC) and another that is 120 volts alternating current (AC). The 12 volt DC system operates off a 12 volt battery. The 120 volt AC system operates when you plug the trailer into a "city" outlet whether at home, in a trailer park, or somewhere else.
I can't help you with most questions. But picture #2 shows the switch, probably for the fan, that lets it operate either off 12 volts DC ("Battery Power") or 120 volts AC ("City Power"). It can operte on either current, but not at the same time.
Your original light fixtures will have 2 Edison type screw in sockets for light bulbs. One side operates on 12 volts DC and the other on 120 volts AC. RV stores sell house-hold size light bulbs that operate off 12 volts DC. If you mistakenly scew one into the 120 volt AC socket, you will get a bright but short-lived flash of light. Use regular low wattage household light bulbs for the 120 volt AC light sockets.
A digital multimeter (VOM to us older guys) will help you identify your electrical circuits and outlets. Just remember, Redi Kilowatt runs half of your tailer. Have fun!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
