Old 06-10-2014, 09:17 AM   #1
Olympia , Washington
Does anyone know what kind of plug-in adaptor I need?
Hi there to the group. I'm taking the family on our first week-long Airstream camping trip in two weeks, and have just learned that I am missing my AC connector cable from the power on site to our airstream. It's a late 50's model, and this is what it looks like. It doesn't seem like a standard pin, can anyone help advise me on exactly what kind of pin this is, what it's called, and where to buy it?
Also--I'm not sure if this is original or not, perhaps it was upgraded by a later owner. I'm 3rd owner on this, bought it about five years ago.
Many thanks!
Name:	trailer electrical 2.jpg
RazAirstream is offline   Reply With Quote
Old 06-10-2014, 09:44 AM   #2
1988 Argosy 32
Lomita , California
It is a 120 Volt 15 Amp male, Any 15 Amp cord, will do
Wolfe is offline   Reply With Quote
Old 06-10-2014, 09:49 AM   #3
1974 Argosy 20
Kooskia , Idaho
It is a change from the original, but as Wolfe says, a standard 15 amp 120 volt extension cord with a single outlet on the end which will fit into the circular hole will work.
Old 06-10-2014, 09:50 AM   #4
Thanks! Much appreciated.
Old 06-10-2014, 10:06 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would suggest a 20 amp cord. The same receptacle configuration.
I assume you do not have an AC unit.
2004 Excursion 4x4
Old 06-10-2014, 10:08 AM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Does your Caravanner have an air conditioner? If not, you're in fine shape and any good extension cord with a female end that fits into the recess should be fine. If you do have rooftop AC, this power inlet is a bit light.
That said, apparently the previous owner of my 28' trailer ran it for years on a 20A extension cord (with a 15A plug hanging under the trailer as the inlet) but that may be why the trailer no longer has its original Armstrong AC unit.
— David
Anyone know what kind and size rivets are on the window frames? deepsea Ribs, Skins & Rivets 11 06-15-2013 11:15 AM
Anyone Know Kind W-D Hitch? catruckn Hitches, Couplers & Balls 10 10-25-2009 08:51 AM
Does anyone know a source for vent plug bertro Ribs, Skins & Rivets 5 02-05-2008 06:27 PM
Need to find adaptor to go from this outlet on my generator to shore power line in AS wacnstac Generators & Solar Power 11 04-27-2006 11:49 AM
