Old 01-01-2007, 03:51 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Does a switch like this exist?
If so, what is it called and where can I get one?
Right now I have the electric portion of the water heater in our 1984 310 Limited MH wired to a three prong cord. When we are parked somewhere with full hook ups, we plug it in and use electricity to heat water.
I would prefer to have it permanently wired to a dedicated 120 V circuit and controlled by a switch. I would like the switch to 'release' if power is lost. It would then be necessary to turn the switch back on when power is restored. Thus the switch would go 'off' when we disconnect and not go back on if I start the generator or hook up again until and unless I manually turned it back on. It would also be nice if it had a light to indicate that the circuit is activated.
Surely such things exist (my table saw has a switch which performs this function) but I don't know what to ask for or where to look. I've browsed the big box stores with no luck.
TIA
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 01-01-2007, 03:53 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Guy99,
Try a local hardware store or electric supply store.
Bill
Just my personal opinion
Old 01-01-2007, 04:16 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by guy99
...Surely such things exist (my table saw has a switch which performs this function) but I don't know what to ask for or where to look...
Your table saw has a "magnetic" switch.
Once energized, a magnetic field keeps the switch contacts closed until opened by the red button or a power failure.
Check a Grainger catalog.
Tom
Old 01-01-2007, 04:16 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Sounds like a magnetic switch, like used to operate heavy machinery. Push the button, and as long as power is supplied to hold the magnet, it will stay on. When power is lost to the magnet, it will release, and turn off whatever it is controlling. Every one I have seen has been a two push button affair.
Old 01-01-2007, 04:51 PM   #5
Ocean Springs , Mississippi
You can do this with a normally open pushbutton switch and a normally closed pushbutton switch and a 120 volt ac relay with at least two normally open contacts. The coil of the relay is wired thru one of the normally open relay contacts. The pushbutton of the normally open switch is wired around (parallel) to this contact. When the pushbutton is pressed, the relay closes the contact and keeps the coil energized. The normally closed pushbutton is wired in series with the relay coil and when it is pressed, it deenergizeds the relay. The remaining normally open contact of the relay is used to switch the heater element on and off. Lots of words to describe this, but it is pretty simple to do.
tfm37 is offline   Reply With Quote
Old 01-01-2007, 06:23 PM   #6
guy99's Avatar
Images: 16
I'd sure like to find a single, packaged component to do this.
I've done some web searches and will check grainger. Seaching on magnetic switch gets lots of hits, but not what I'm looking for.
Anyone else have an idea about a source or what search terms I should use?
Old 01-01-2007, 08:06 PM   #7
Images: 59
Look for "Magnetic starter" rather than switch. Here's a cheap one: G8291 Magnetic Switch, Single-Phase - 110V Only, 2 HP
edit: you can also get a remote on-off pushbutton, and a indicator light.
markdoane is online now   Reply With Quote
Old 02-03-2007, 04:28 PM   #8
Loren's Avatar
Found one
guy99,
Here's one, but you won't like the price:
McMaster-Carr
search for catalog # 8230K24
They also have some others on that catalog page that may suit your purpose and cost a bit less.
Loren
2012 New Horizons Travel Trailer (formerly an Airstream owner)
2008 Dodge 2500 diesel with Equal-i-zer hitch.
Loren is offline   Reply With Quote
Old 02-03-2007, 04:55 PM   #9
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
hello the one markdoane has listed is the one you want.$53.00 is a good price.
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 02-03-2007, 05:19 PM   #10
Images: 59
Uh, the one in McMaster-Carr won't even do the job, it's just a pushbutton non-magnetic switch.
Old 02-03-2007, 06:29 PM   #11
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Yes, the switch you want is available. Go to your local electrical industrial supply warehouse and describe what you want. They will be able to help you.
Pop Rivet is offline   Reply With Quote
Old 02-03-2007, 07:20 PM   #12
zamboni's Avatar
What about a On-off-On switch, you could add/wire the indicator light yourself.
zamboni is offline   Reply With Quote
Old 02-03-2007, 09:50 PM   #13
Loren's Avatar
Mark's right
guy99,
Sorry, I thought I had found one, but after closer reading of the description I see that Mark's right. The McMaster-Carr switch isn't magnetically held. It won't do what you want it to do.
Good deal, huh? Just think of all the money you saved.
Loren
Old 02-03-2007, 10:41 PM   #14
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
If you like the one on your table saw, order one from that saw manufacturer.
Fyrzowt is offline   Reply With Quote
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
