Old 12-22-2018, 05:40 PM   #15
1971 27' Overlander
Kansas City , Kansas
I'm going to try leaving them up and see if it increases aerodynamics!!!
Shermy1987 is offline   Reply With Quote
Old 12-22-2018, 06:41 PM   #16
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Less wear on the tires.
Mattirs is offline   Reply With Quote
Old 12-22-2018, 09:26 PM   #17
Wconley's Avatar
2018 28' International
Renton , Washington
I just made my own from 1/8”x1” aluminum bar with parts from Lowe’s. Cost was about $15 per panel. I don’t expect to use them very often but this winter plan on some Boondocking and every bit helps in the winter.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 01-02-2019, 05:40 PM   #18
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I use tilt bars for my two 100 watt portable panels. I no longer use shore power to keep my batteries charged. The panels are set facing south to get as much direct sun as possible in the winter. Performance varies from about 10 watts with full cloud cover to 60 watts when the sun is out.
DanClick image for larger version
Old 02-14-2019, 08:28 AM   #19
Wconley's Avatar
Renton , Washington
We are in Utah and I used my home made bars for the first time. Tilting three of our four 100-watt panels increased our output from about 200 watts to 320 watts! The fourth panel is shadowed by the AC housing so it didnít make any difference. My bars are home made at about half the cost and are adjustable to two different angles so Iím very happy with the 30 minutes making them. Iím finding that the shallower angle (not shown in the picture) is about the max I will need so I may cut the bars down when I get home.
Itís currently very sunny so the battery was fully charged within an hour or so of the sun coming into the canyon. However, itís going to get rainy in a couple of days so we will need all the power we can get.
Walt
2013 F150 Ecoboost
Seasonal tilt adjustment of solar panels Bob Blarney Generators & Solar Power 8 09-21-2018 08:17 AM
Hehr vs. Full tilt windows. Soyboy Windows & Screens 28 03-17-2012 07:55 AM
Tilt-a-rack . Advice needed. Thanks Octane General Motorhome Topics 9 09-09-2011 03:19 PM
Tilt Switch source? pwhittle Mechanics Corner - Engines, Transmission & More... 2 04-22-2009 07:38 AM
Tilt Mechanism - Lookout Blinds xengineer Upholstery, Blinds, Walls & Interior Finishes 0 09-01-2008 05:09 PM
