Old 07-06-2017, 07:19 AM   #1
Norfolk , Arkansas
Do I need a special connector?
Hi, newbie Airstreamer here with EVERYTHING to learn. My 1972 Ambassador Land Yacht came with a battery-less compartment. Any recommendation on a perfect battery? And as you see, the battery cable is not capable of attaching to battery terminals. Is there a special connector that is proprietary to an Airstream, or can I just cut off this end, strip red and black wires and clamp new post connectors direct?Click image for larger version
gameworden is offline   Reply With Quote
Old 07-06-2017, 08:46 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
There are no special connectors to worry about, conventional Group24 and Group27 deep-cycle batteries usually have both bolt-on and clamp-on terminals. You'll want the largest battery that's a good fit... in my '70s Argosy trailer all that would fit was a Group24 but someone who's used one of those low side battery compartments from a silver 70s trailer can tell you if a Group27 will fit. If I were starting from no battery at all I'd look for an AGM battery, in my opinion that's the price-vs-performance sweet spot right now.
— David
Old 07-07-2017, 06:42 AM   #3
Norfolk , Arkansas
Thanks so much David!
Old 07-07-2017, 06:47 AM   #4
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Just curlous if you are restoring your Land Yacht for personal use of for sale?
Old 07-08-2017, 12:29 PM   #5
Norfolk , Arkansas
Hans, looking to restore for personal use and professional use. I am a 44 year radio broadcaster who wants to do a mobile version of my radio show using the Airstream. My dad always used to tell me that everything is for sale for a price… So I guess that would be true as well, but that's not really the plan I have at all. Interesting thing though about the term "restoration and "as despite the fact that it's 45 years old, I very much like the kitsch and style of mid century and turn of the century. You see so many stories about the condition of trailers this old and you expect that you will have to do some kind of major overhaul or maybe even gut the unit. I do intend on recording broadcasts as well as live music inside the space, but the interior is in such amazing shape, I really don't see myself changing a whole lot other than modernizing the carpet, window treatments and upholstry perhaps. I'm really looking forward to finding ways to learn from people in this forum on the ins and outs of modernizing affordably. At this time, I'm not worrying so much about getting the decor just right, I just want to get it road ready so I can begin my next broadcast chapter in a unique way.
Old 07-08-2017, 12:39 PM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Step back a bit and consider your use case before doing any battery "stuff". Are you headed off into the "solar only" / off grid world? If so big batteries (and probably lots of them) matter. Will you be on shore power 99% of the time? Just about any battery is fine in that case. The range of possibilities has expanded quite a bit since 1972....
Old 07-08-2017, 09:02 PM   #7
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
Those are the correct connectors for deep cycle batteries.
fwjumper is offline   Reply With Quote
Old 07-08-2017, 10:02 PM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Zooming the picture, that connector looks to me like some I have seen on a power cord for 12V equipment. 12V deep cycle batteries will have studs for ring terminals, perhaps in addition to conventional battery posts.
Further, the wire gauge looks too small, but it is hard to tell for sure from the picture. OP could cut the connector off and add a couple of properly sized ring terminals for starters.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 07-08-2017, 11:13 PM   #9
1979 23' Safari
Wayland , New York
The wire you're looking at is a quick disconnect. One looking like it was connected to the battery so the battery could be unplugged easily for removal. You can get replacements or cut it off and bolt the wires onto new terminal connections if the wires are long enough.
Old 07-10-2017, 08:34 AM   #10
Half a Rivet Short
Hi
If you decide to keep the thing set up with connectors (they do make things a bit easier). Consider replacing those old ones with something new. Anderson Power Poles are one option. There are a lot of others. As others have noted, we now live in the era of inverter technology. That means high current loads. Upgrading the wires is a good idea.
Old 07-11-2017, 05:01 PM   #11
Norfolk , Arkansas
Thanks so much for the suggestions!!!
Old 07-28-2017, 07:00 AM   #12
Norfolk , Arkansas
Hi
Thanks so much Bob. Still weighing options. Some great food for thought here.
Old 07-28-2017, 07:35 AM   #13
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Look into lithium. their initial CAPEX cost is higher, but they last longer, run longer, and have a higher capacity.
there are many threads in this forum
waninae39 is offline   Reply With Quote
Old 07-28-2017, 07:35 AM   #14
Norfolk , Arkansas
Thanks so much!
Old PB Tee Connector Leak, need help finding replacement! Rhino33 Fresh Water Systems 5 07-30-2014 10:20 AM
need a special thermostat johnfarrow Refrigerators 4 05-18-2010 02:49 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
Need Special favor from admins. Hit'nMiss Forum Admin, News and Member Account Info 4 02-16-2005 09:04 PM
