Old 02-16-2010, 01:44 PM   #1
1971 31' Sovereign
po'dunk , Georgia
do I need a battery
I'm new to airstreams but I already love them and it's only been a few weeks. My question is do I need to have a bat hooked up if I'm using shore power ? Will this hurt anything by not having one ? Thanks... By the way great info on this forum I hope to learn alot from you guys...
nickfxstc is offline   Reply With Quote
Old 02-16-2010, 01:56 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Yes you do. The brake system works off the 12v system as does the the rest of the 12 volt system.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-16-2010, 02:26 PM   #3
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Yes you should have one. Most chargers are made to charge batteries, not run continous. Also need for running down road as stated in previous post.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 02-16-2010, 02:34 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I may be wrong but your trailer brakes (I was lead to believe) run of you hook up to the truck. Mine still worked when my battery was complete dead after leaving a camp site one time. The converter changes the shore power into 12v to run stuff when hooked up. You battery is only used when not hooked up to shore power....
So my answer would be No.. If you are always hooked up you don't need a battery in the trailer...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 02-16-2010, 03:25 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
In the event of the trailer breaking away, the battery is the only way to power the brakes.
Vaughan
Old 02-16-2010, 03:30 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes the battery is like a limiter to the charger. It provides a constant voltage supply where as the charger may max out if you have a lot of things on at one time. A battery can supply much more current when there is a large load, everything on at once, than the charger can. Also the charger will put out as much as 14.7 volts. if you were to turn on just 1 light under this condition the life expectancy of that light will not be long.
As for the trailer brakes they work off the TV electrical supply under normal driving. However if your trailer was to come loose of the TV while traveling the trailer battery will then put the trailer brakes on at FULL POWER once the cable attached to the TV has pulled the pin out of the emergency switch. These 2 12 volt systems have nothing else in common.
2004 Excursion 4x4
Old 02-17-2010, 04:32 AM   #7
1971 31' Sovereign
po'dunk , Georgia
I just wanted to thanks everybody for the great answers. I'm sure I'll have for questions thanks...
Do I need a battery? tphillips Batteries, Univolts, Converters & Inverters 1 03-03-2009 07:51 PM
Battery in a 58 ? 60's Iron Batteries, Univolts, Converters & Inverters 5 07-19-2006 07:31 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Getting a new Battery ChrisAich 2002 - 2005 International 0 10-09-2003 02:25 PM
