Old 06-16-2013, 12:06 AM   #1
1967 17' Caravel
georgetown , Texas
Do I have to install a 12 volt fuse panel?
Hi,
I have a 67 Caravel that i am doing a frame on redo. Right now, I am working on the electrical. I have a 70 y.o. master electrician doing the majority of the work.
It was completely gutted. New wiring. New panel. New Progressive Dynamics 9245 converter. two batteries on the tongue.
Question - He did not have a 12 volt fuse box/panel and is deciding to not put one in. Is this a bad idea? If one is not installed, what can happen or worse thing that can happen?
There is a fuse on the converter, i guess that protects it from surges, etc.
I dont have too many 12 volt circuts going. Mainly lights. An outlet, fantastic fan that has a fuse.
knishiya is offline   Reply With Quote
Old 06-16-2013, 06:27 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Every 12V circuit should have it's own fuse. 12 Volt DC RV panels with a several lines are not expensive and I would certainly install one. Now is the time. An arched 12V from a big 12v battery carries lots of amps and you don't want that to happen. The 68's had a "control panel" which is up front which is basically a fusebox for the 12V system. Each 12V circuit has it's own breaker. I think the 67's had fuses/breakers back near the battery area and you can go back like the original if you don't want to buy a new panel. I'm sure someone here can send pics if you need them.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-16-2013, 06:44 AM   #3
toastie's Avatar
1955 22' Safari
Great Lake State , .
Yes
See my post #601 and #602 http://www.airforums.com/forums/f36/...-38289-43.html
See post #416 http://www.airforums.com/forums/f36/...-38289-30.html
Attached diagram which calls for a fuse at 55 amps and no greater than 18" from the battery
toastie
toastie is offline   Reply With Quote
Old 06-16-2013, 06:52 AM   #4
2008 16' Safari
Destrehan , Louisiana
Yes, don't skimp on safety.
dlb435 is offline   Reply With Quote
Old 06-16-2013, 07:56 AM   #5
Ottawa , ON
Having a fuse in each line of 12V current draw allows you to carry on with the good circuits should one line become shorted.
They also prevent excessive current draw, which could cause a fire.
No choice: you really need them on each line.
I've attached a photo of the one we liked and bought from Vintage Trailer Supply. Easy to use, and it has a door to protect all circuits.
Old 06-16-2013, 09:15 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If he doesn't think the 12 volt circuits need individual fuses or breakers you need an electrician that doesn't want to take dangerous short cuts.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-16-2013, 09:25 AM   #7
Originally Posted by knishiya View Post
Hi,
Fuse panels are absolutely necessary in any electrical circuit.
They prevent fires and deaths because of a fire.
Your friend needs to practice safety, period.
His "master technician" permit should be revolked, pronto, before his misguided advice causes a death.
Old 06-16-2013, 09:46 AM   #8
lewster's Avatar
Naples, FL , Hood River, OR
I might as well pile on a little...............
According to RVIA standards and the NEC (hopefully, your 'master electrician' knows what those initials represent), every circuit, whether AC or DC, should have over-current protection on it to be sized according the the wire gauge being used.
That means an AC circuit breaker on every line entering the AC circuit breaker panel (hopefully you have on of these...) AND a DC fuse on every DC circuit.
Again, ampacity is determined by the wire gauge, as in 15 amps for 14AWG and 20 amps for 12AWG. You should also have a main DC fuse or circuit breaker located within 18" of the batteries sized to the cable leading to your DC fuse panel, as the purpose of a fuse or circuit breaker IS TO PROTECT THE WIRE
Old 06-16-2013, 10:16 AM   #9
Crusty's Avatar
1992 34' Excella
If you only have a few 12v circuits, you might be able to get by with inline fuses in each circuit, though I consider them to be a bit on the troublesome side. I would at least look for marine fuse holders so that they're somewhat protected against moisture and they should be located as close as possible to the 12v source.
Electrical fires which start in the night when the RV occupants are asleep can kill.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 06-17-2014, 08:37 AM   #10
1974 27' Overlander
Placerville , California
Hi,
I know this is an old post but it would be nice to here from original poster as what was done. I am an auto tech and yes you must have a fuse panel or inline fuse to protect each circuit. The electrician would know this seems that there may be some confussion as to what he is planning. What did you end up doing? If installed which panel did you use. This info can be helpful others doing the same thing.
Ron L
ronsgto is offline   Reply With Quote
Old 02-05-2018, 09:58 AM   #11
1973 31' Excella 500
Dallas , Texas
Thread Revival! If I'm counting correctly, I have/will have over 25 DC circuits in the AS Excella 500, not including the 4 or 5 for the exterior trailer lights (running, reverse, etc.) which do not seem to have any original fuses. Am I reading correctly that I need a fuse for each of these circuits?? The original Univolt system only had about 8 fuses - and many of the same circuits (per the manual), so I'm wondering if several things can be combined (like power-sipping LEDs). If I can't combine them, what Power Center provides a DC fuse board that big (currently looking at this Boondocker 60 Amp which only has about 12 DC circuits).
Listed below are the DC circuits I'm counting - any additions or corrections would be appreciated!
1) 2 x Bed Lamps
2) Trunk Light (external access compartment)
3) 4 x Speakers
4) SeeLevel Tank Monitors
5) Bathroom Exhaust Fan
6) 2 x MaxxFan Deluxe
7) Composting Toilet Fan
8) 3 x 12V Outlets
9) 2 x Bathroom Lights (overhead & mirror)
10) Air Conditioner Thermostat
11) 2 x End Cap LED Strip Lights
12) Radio/Stereo/Bluetooth System
13) Livingroom/Kitchen Ceiling Lights
14) Bedroom Ceiling Lights
15) Water Heater Ignition
16) Furnace/Heater Ignition
17) Oven Light
18) Connection to Batteries (circuit breaker or fuse?)
19) Solar Hook-up (charge controller might serve as this fuse?)
20) Water Pump
21) Awning Lights
22) Porch Light
23) Cabinet/Drawer LED Lights
24) Closet LED Lights
25) Doorbell (this will probably be removed completely)
Thanks for any help!
Drew
DriftingDrew is offline   Reply With Quote
Old 02-06-2018, 05:37 PM   #12
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Just like every AC fixture doesn't need its own circuit, either does every DC fixture. You need to figure out what you can combine based on its required amps and what makes since based on the path of your wire and then size the wire and fuse appropriately for each circuit.
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 02-07-2018, 09:48 PM   #13
2016 30' International
redondo beach , California
And I'll pile on too. My 2016 has a 6AWG wire going from the battery directly to a 12V bus in the front of the trailer. There is no DC fuse or circuit breaker. The electrical drawing shows a circuit breaker but AS did not see fit to put one in.
Bummer.
But you are correct and I will install one.
Randy and Beth
2015 F250 Titan 50 gallon tank
2016 International ProPride, EasyStart, Michelin 16", Battle Born LiFePO4 x 2, PD 60 Amp converters x 2, Victron BMV 712, Orion 12/12, and Blue Solar MPPT all in a rolling experiment
Nobody's perfect and I'm a perfect example
mythbuster88 is offline   Reply With Quote
Old 02-08-2018, 05:46 AM   #14
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Remember, the fuse is there to protect the wiring, not the electrical loads themselves. Combine the smaller loads on the same circuit where it makes sense. Give the big loads their own (adequately sized) wire and breaker.
12 volt
