Old 04-17-2009, 02:55 AM   #1
1982 28' Airstream 280
Buena Park , California
Distribution Panel
1. Batteries
2. Battery Solenoid
3. Starter
4. Ammeter
5. Solenoid
6. Voltage Regulator
7. Alternator
8. Isolator
9. Circuit Breakers
10. Fog Light
11. Ignition
12. Distribution Panel
Sorry for the crude schematic, but it was the best I could do.
So here is my situation. I recently parked the motorhome after a 40 miunte drive, went to lunch, and it would not start. Starter didnt make any sounds and the battery was fully charged. A mobile repairman came buy and started it right up for 50 cents. He took two quarters and touched the two terminals on the starter. He said there is probably a short somewhere. I found two problem areas, but it seems to be more than that. The distribution panel is not getting any voltage.
Where does the distribution panel get connected to the electrical system?
It is a diesel engine. Currently I am still using the quarters to keep the motorhome running.
kennytheecat is offline   Reply With Quote
Old 04-17-2009, 03:02 PM   #2
Bump
Old 04-17-2009, 03:20 PM   #3
Images: 59
#8.
Old 04-17-2009, 05:29 PM   #4
I found a previous post from someone one who is having my problems exactly that has 8 pages of responses. No power to the fuse panel on either side, only one of side of teh isolator is hot, ....
Distribution panel upgrade nd48463 Batteries, Univolts, Converters & Inverters 6 05-23-2009 01:14 PM
Where is the Low Voltage Distribution Panel on a '69 Tradewind? monah Lights - Interior & Exterior 1 04-13-2009 05:23 PM
Fuse/12V Distribution Panel Mike S Batteries, Univolts, Converters & Inverters 5 11-13-2008 10:05 AM
Low voltage distribution panel...Help k9s2go Electrical - Systems, Generators, Batteries & Solar 4 12-29-2006 01:54 PM
