Old 01-28-2016, 05:01 PM   #1
111
2015 23' Flying Cloud
Moses Lake , Washington
Disconnecting tank heaters.
2015 23D FC. I will be dry camping with this trailer and do not wish to have the tank heaters drain down my batteries in cool weather.
The two heater fuses are well marked and easy to remove but I also lose my USB port power.
Is it possible to pull the board out and rewire the circuit so I can use the USB ports?
Has anyone installed switches to the tank heaters?
Thanks in advance..
111 is offline   Reply With Quote
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 10:20 AM
Disconnecting Shower Drain ? AldeanFan Plumbing - Systems & Fixtures 3 10-09-2013 04:55 PM
Disconnecting the batteries Bobdes Batteries, Univolts, Converters & Inverters 6 06-02-2011 03:51 PM
Battery Disconnecting on Solar Application jeff4506 Generators & Solar Power 4 11-24-2008 07:32 AM
Disconnecting toilet from tank vishwa Airstream Motorhome Forums 1 09-06-2003 02:25 PM
