Old 08-21-2006, 07:15 PM   #1
Barron , Wisconsin
Question dim lights
My 1973 Sovereign has dim lights while plugged into shore power..what's wrong??? Its like the lights are running from the battery only. Would all be fine with a new battery?? Is the converter shot?? Please help!
dallas is offline   Reply With Quote
Old 08-21-2006, 07:19 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
First thing you need to do is measure your DC Voltage. Post your findings and then we can help.
Measure across the battery posts with the traielr plugged in, and then unplugged from 120V
Also, if you can, you might measure the voltage at one of the lights that are dim.
Uwe
www.area63productions.com
Old 08-21-2006, 07:44 PM   #3
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Dallas,
Well, I just have to ask . . . does it have it have BRIGHT lights when you're NOT plugged into shore power or are they just dim all the time?
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-22-2006, 01:42 PM   #4
Dim lights
Dallas,
Your Univolt probably is not working to charge the batteries. We had the same problem on our 71 Safari until a friend replaced a resister inside the Univolt.
Dan
Dbraw is offline   Reply With Quote
Old 08-22-2006, 04:22 PM   #5
Barron , Wisconsin
There is a black plug under the stove that I can connect a little charger on to and after a couple of hours the lights are much brighter for a while after I disconnect but than it seems the charge is weakening and they go back to being dim. There is also a black rocker switch that looks like it is factory installed down towards the bottom of the wall the stove is on that I can click three ways and one of them makes the convertor or univolt system hum. Any way I do the rocker switch the lights stay dim.
Old 08-22-2006, 04:27 PM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Sounds like perhaps the Univolt, or the battery wiring is having problems.
The lights should brighten as you turn on the Univolt.
If the auxilliary charger brings more brightness to the lights, than that measn that tere is a temporary charge on the battery. This would be the Univolt's job, to keep the battery charged and keep the light bright.....
Uwe
Old 08-22-2006, 04:33 PM   #7
Barron , Wisconsin
Dan, I think you are on to something. I thank you for you time. Dallas
Old 08-23-2006, 08:25 PM   #8
Barron , Wisconsin
Thank You I believe it is the Univolt. Dallas
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
