Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-24-2010, 12:10 PM   #1
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Different DC Cigarette Plug Receptacles?
I have a 2004 22' CCD.
I have noticed that my front DC cigarette receptacle is different from the one in the back, under the desk. The front receptacle is deep and will accept the plugs. The rear receptacle/TV booster is shallower and will not accept the same plugs.
Why the difference? Can I get one replaced to match the other? It seems that the front one is the best.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 07-24-2010, 12:38 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Same problem.
The ones in the TV booster seem to have a slightly smaller diameter, and are too tight for most plugs.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 07-24-2010, 12:47 PM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
This problem of different sized 12V outlets was discussed several months ago - but I can't remember what the solution was. If you do a search you might turn the thread up.
Al - K4GLU is offline   Reply With Quote
Old 07-24-2010, 01:19 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
My solution was to mount 12v outlets elsewhere. They cam be purchased at most any Auto Parts store. I went straight from the 12V panel in the front of the trailer, and used #10 wire. That way you can power just about anything you wish. The wires going to the booster are small. Not really very useful.
Old 07-24-2010, 03:25 PM   #5
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
A few years back I had this exact problem. I'm not at my unit, but I believe it was the one that was had on on/off switch for the Wingard antenna.
I called Wingard, explained the problem, which they are aware of, and they sent me a replacement plug/plate thing. Still a tight fit but better. I don't use that 12v. socket for much of anything anyway.
Give Wingard(?) a call.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-14-2010, 07:03 AM   #6
rseagle's Avatar
Images: 33
Solution!
I took the trailer to my local Airstream dealer and had the old DC receptacle replaced with a Winegard Wall Plate Power Supply (Model RV-7042). I works fine with the newer DC plugs.
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
have 110 receptacles no overhead lights michaelsessa Lights - Interior & Exterior 4 04-29-2007 06:45 PM
Interior receptacles behind curtains davidz71 General Interior Topics 1 01-31-2006 07:53 PM
Electrical Receptacles don't work now goldenlily Electrical - Systems, Generators, Batteries & Solar 1 10-03-2005 12:39 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
