Old 02-08-2017, 01:49 PM   #1
Ge0
Phenix City , Alabama
Did I mess up with my generators
I recently purchased 2 Honda EU2000i generators with the parallel connection cables and I was not aware of the Honda EU2000i companion that has the 30amp receptacle built in. My current receptacles with my units are standard house type plugs. Did I mess up with this or can I use some kind of adapter so I can power my A/c?
Ge0 is offline   Reply With Quote
Old 02-08-2017, 02:13 PM   #2
bwpaint's Avatar
2015 25' FB International
my , house
I think this will solve your problem. http://www.rvpartscountry.com/HONDA-...FU08gQodzH8Akg Take a look and see if it will work for you.
bwpaint is offline   Reply With Quote
Old 02-08-2017, 02:28 PM   #3
Ge0
Got it, and thank you for helping!
Old 02-08-2017, 02:31 PM   #4
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
The companion makes things simple.
Old 02-08-2017, 02:32 PM   #5
Ge0
I understand now. When I bought them I did not see the companion. Live and learn I guess!
Old 02-08-2017, 02:33 PM   #6
2015 25' FB Flying Cloud
Meadow Vista , California
Do you need that part to run your AC or can you use an adapter?
SS
SilverSinbad is offline   Reply With Quote
Old 02-08-2017, 02:40 PM   #7
bwpaint's Avatar
my , house
SS
You just need the RV adapter and the parallel cables if one of your generators is a companion. If you don't have a companion, only two standard 2000 hondas, you need this kit to give you a 30 amp circuit.
Old 02-08-2017, 04:59 PM   #8
Tin Man
LY007's Avatar
1983 27' Excella
Charlottesville , Virginia
That $190 cable at rvcountry is $50 at Amazon without that extra box. I just use the $50 cable to run AC with my two Hondas
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 02-09-2017, 05:44 AM   #9
bwpaint's Avatar
my , house
The box is to provide a 30 amp circuit. Only 20 amp circuits available without a companion generator or the Honda parallel kit.
If 20 amps is sufficient, then you are correct, all you need is the cables.
My AC, 15,000 BTU, trips a 20 amp breaker if anything else cycles on with AC running.
Old 02-09-2017, 11:35 AM   #10
2015 Interstate Ext. Coach
Tigard , Oregon
Best Fuel for Honda
Have had EU2000i & companion for 3 years. Recently, in Eco Mode, one of the generators started running very roughly. Took it into local Honda dealer who cleaned fuel lines & carburetor with a suggestion. If you are in a state requiring ethanol infused gas, it will accelerate deterioration in your fuel line/system. While additives help, they suggested using "clear gas", non-ethanol fuel only. Here, it currently runs about $4.50 a gallon & available only at a few gas stations. The problem is compounded by cheap metals being used by foreign manufacturers on engine parts that break down more quickly.
Oldforester is offline   Reply With Quote
Old 02-09-2017, 11:49 AM   #11
greenflag's Avatar
2016 30' International
Quartz Hill , California
I have a parallel kit on one of my 2000's. It works great.
greenflag is offline   Reply With Quote
Old 02-09-2017, 12:13 PM   #12
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
Oldforester, get some Startron fuel additive and pour a little in with your generator' gas. It has an enzyme that removes the ethanol leaving you with gas that won't cause the problem you described. The dealer where I bought my generators (2 Honda 2000s) highly recommended it and I've had trouble-free operation of my generators even after they sit unused for months on end. I add it to the fuel for my lawn equipment and motorcycle too. Startron is available at most auto parts stores in your area.
Nomad518 is offline   Reply With Quote
Old 02-09-2017, 12:56 PM   #13
rogerdog1's Avatar
2013 25' FB International
Littleton , Colorado
Can you still try to return/exchange it for the right one?
rogerdog1 is offline   Reply With Quote
Old 02-10-2017, 07:14 AM   #14
Ge0
yep, sent it back yesterday.
What a mess... dmac Axles 21 05-24-2006 09:41 AM
I'm too trusting i guess now look.. what a mess!! Angel73 Repairing/Replacing Floor &/or Frame 8 05-07-2006 04:44 PM
Weight Distribution Bars-Avoiding a mess JaceBeck Hitches, Couplers & Balls 18 11-25-2004 12:29 PM
How'd I mess this one up? Safari Tim On The Road... 1 08-13-2004 05:48 AM
Well,..I've REALLY got a Mess Going Now !! MileHigh Cleaning, Stripping & Polishing 7 01-11-2004 07:51 PM
