Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-30-2002, 01:35 PM   #1
26Argosy.ca
26Argosy.ca's Avatar
Profile:  Cardigan , NB
Question deep cycle battery replacement
Hello
I have 75 Argosy MH, some ten years ago it was modified to have a large deep cycle battery stored below and just behind the drivers seat, it can only be accessed from outside and does not enter the living space. That said, I wish to replaced it with 3 or 4 car batteries that are of the GEL type, together in series.
The old battery is of the water type and has or is leaking and rusting the metal tubing in that area.
What are the pros and cons of this idea.
Thank you much!
Onne de Boer
26Argosy.ca is offline   Reply With Quote
Old 12-30-2002, 02:46 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
If they are 12v they need to be in parallel. How big a battery is in there now? I take it this is custom made for a specific size battery. You might be able to get more capacity by using the same size battery than 2 or 3 smaller ones than won't total as much current because of physical size; gel cells come in every size a lead acid battery does.
John
74Argosy24MH is offline   Reply With Quote
Old 12-31-2002, 06:51 AM   #3
zamboni
zamboni's Avatar
Profile:
caution
Bobby is correct. You will want to make sure you install them in parallel configuration...or you will end up with a 24 or 36 volt system depending on how many batteries you decide to install.
Think of it like a small radio which requires six volts to operate and if you install the AA bateries according to the directions (pos + to neg -) you will total the six volts required to power that radio.
Same principle here. If you wire pos + of one battery to the neg - of the next and so on until you hook up to the electrical system, you will had added the output of each battery to the next. Thus being larger than the required 12 volt dc. If you wire the bateries in parallel...pos + to pos+ and neg - to neg - ... you will have only increased the total "holding" capacity for providing 12 VDC to your system.
zamboni is offline   Reply With Quote
Old 01-01-2003, 06:33 PM   #4
26Argosy.ca
Thanks, You're right, I knew how to hook it up, I had the two names, series and parallel switched.
I would like a gel battery under there so there is no more leakage. I will look into various sizes. Then I can then get to restoring the metal that has been corroded.
Again Thank you
Old 01-01-2003, 07:53 PM   #5
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
You may want to look into this product for your restoration and future protection onf the corroded metal
POR 15
Many members have used it and I have a can just waiting for the day I pull up my carpet. I have 1 more leak to find and then it is carpet time.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 01-02-2003, 03:13 AM   #6
74Argosy24MH
Windsun has a good selection of Concorde agm batteries. They have a good site with all the sizes listed so you should be able to find a compatible size.
John
Old 01-02-2003, 05:19 AM   #7
26Argosy.ca
Thanks again, I have the POR 15 info on my desk, I picked that a few weeks after I bought the MH.
I'll check out Windsun for Concorde batteries.
O
Solar trickle charger.... drboyd Generators & Solar Power 27 09-20-2003 07:51 PM
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Replacement Battery heyskipper Electrical - Systems, Generators, Batteries & Solar 28 04-04-2003 07:06 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
