Old 12-07-2019, 10:02 PM   #1
1978 Argosy Minuet 6.0 Metre
toronto , Ontario
Decision on 30A versus 50 amp inlets
Hello, I am renovating a 1978 Airstream Argosy Minuet and about to start rewiring, and am wondering whether i should just go ahead and make the inlet 50amp, as it was previously only 30A but may need the extra power. thoughts, JeremyHB
jeremyHB is offline   Reply With Quote
Old 12-07-2019, 10:13 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The most popular reason to upgrade to 50 amp is adding a second AC unit. I don't think that would be practical on your size trailer. What do you see as a need for the additional amperage?
Richard
Old 12-07-2019, 11:15 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
30A is more common than 50A
unless you need two Ac units, go 30A
waninae39 is offline   Reply With Quote
Old 12-08-2019, 08:38 AM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I'm renovating a 78 6.7m Minuet myself and 30 amp will be enough. 50 amp wire is a lot heavier.
Coosa subfloor going into mine right now.
Goodluck with your reno
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-08-2019, 09:27 AM   #5
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Agree with the above. Unless you have an unusually high energy need 30A makes sense. Also, the installation cost rises quite sharply with 50A (6AWG, larger breakers, etc). Id suggest you estimate how many amps youll draw before moving forward. For example, it would be unusual to use all five of these at the same time:
8A microwave
10A water heater
13A air conditioner
8A furnace fan
10A hair dryer
Other items:
? Converter
? Refrigerator
? Electronics charging (laptop, etc)
Another option is to consider using a 30A system but install a hybrid inverter that will convert battery power into AC if you temporarily exceed 30A. For example, Victrons Multiplus line does this.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 12-08-2019, 10:10 AM   #6
SilverPal2's Avatar
1954 22' Flying Cloud
Ojai , CA
Send a message via ICQ to SilverPal2
The 50amp connector and circuitry are intended to be used in a 220V system therefore unless you plan to do a 220V conversion you stay with the 30amp connector
WBCCI 261 AirForums 24539
JamesPolk@PolkValuations.com
Accredited Appraisal Firm www.PolkAssociates-LLC.com
SilverPal2 is offline   Reply With Quote
Old 12-08-2019, 11:05 AM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
...go with 50
Old 12-08-2019, 11:09 AM   #8
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I removed my second ac and had the rig converted from 50 to 30. I hated that big-a 50amp cable. (And the ac over the bed, too).
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-08-2019, 11:24 AM   #9
1976 31' Excella 500
Chappell Hill , Texas
Originally Posted by tjdonahoe View Post
...go with 50
Agree. Go 50A and you can run more stuff at once. One less worry down the road.
tbashin is online now   Reply With Quote
Old 12-08-2019, 11:31 AM   #10
Iron tepee #35
1993 34' Excella
andalusia , Illinois
If you plan on any winter camping the extra ampacity could e handy with electric heating.
mikeoxlong is offline   Reply With Quote
Old 12-08-2019, 11:34 AM   #11
2019 30' Flying Cloud
Homosassa , Florida
I would go 50. If you want to run a microwave and a/c at the same time 30 probably won't do it especially of an converter for batteries and/or refrigerator is on at the same time. You can always use less with 50 amps (12,000 watts) available than 30 amps (3,600 watts) but with 30 you can't use more.
Tater is offline   Reply With Quote
Old 12-08-2019, 12:49 PM   #12
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Are you camping? Or bringing your house with you. At 230 volts 50 amp you are close to 4X what you will use. Unless you are going to have a jacuzzi. I often just use a 20 amp service. If I don’t need air conditioning.
bibbs is offline   Reply With Quote
Old 12-09-2019, 09:08 AM   #13
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
120 vac 30a
Agree. You should only use a 50A inlet if you are rewiring the entire AC system from a 240/120 VAC load center. Otherwise, stay with 120 VAC 30A inlet and load center. 30A seems plenty good for your trailer size.
Recommend looking through these before you start: NFPA 70 2020 edition, National Electric Code, Article 551 and NFPA 1192 2018 edition, Standard for Recreational Vehicles.
For the inlet itself, we are extremely pleased with our SmartPlug.
73/gsu
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 12-09-2019, 09:19 AM   #14
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
While I agree that the OP doesn't need 50A service for the Minuet, your reasons here are misleading. While the 50A shore power inlet makes 240v AVAILABLE (the difference between the 2 "hot" legs is nominally 240v) RVs with 50A shore power are generally wired as 2 legs of 120v 50A service for a total available power of 100A at 120v. All appliances and systems in a 50A Airstream are 120v, for example.
David
Old 12-10-2019, 01:33 PM   #15
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
.......everything in the As is 110 volt...1 ac and water heater with microwave is cutting it very close for 30 amps...
Old 12-16-2019, 01:00 PM   #16
toronto , Ontario
Cheers
Sidekick Tony
Thanks so much for info, I think that I am sticking with 30amp. I am also considering the Coosa board for my subfloor so it was great to see your tests.
jeremy
Old 12-16-2019, 01:53 PM   #17
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
There is no conversion other than adding another wire between the shore power input and the breaker panel and upgrading that wiring to a larger gauge. All that wiring is heavier, but it is usually very short. In my trailer it is is less than 6 feet. Everything past the breaker panel remains the same, i.e 15 and 20 amp breakers and supporting wire.
That said, unless OP plans some heavy power consumption like 2 ACs or residential stove-top/oven, 30A should be sufficient.
It is possible, however, to overload a 30A service by using AC, water heater on electric, microwave and converter, so some power management may be needed with 30A that is not with 50A.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Fast Eddie & Kool Karen's Decision Process To Date (long) FastEddieB Dollars & Cents 45 05-13-2014 08:44 AM
Rubber grommet inlets for black tank? vhord Waste Systems, Tanks & Totes 3 03-20-2008 02:02 PM
30A Upgrade to 30A + 20A Wayne Olson Classic Motorhomes 10 12-12-2006 04:51 PM
