Old 05-02-2015, 02:05 PM   #1
2008 19' International
Coupeville , Washington
Dead system
I've had my AS ('08, 19') in storage for several months. I expected the batteries to be dead, but after being plugged into shore power, I'm still completely dead. When I'm plugged in, all lights, etc. function fine. Any ideas?
portageking is offline   Reply With Quote
Old 05-02-2015, 02:34 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
First, make sure the use/store switch is in "use".
Second, make sure when you push the button, you hear the "clunk" of the solenoid engaging.
Third, some models had a wiring issue from the factory, where if the battery is completely stone dead, the converter will not charge it. The quick fix for this is to connect a battery charger to the batteries for a few minutes so the converter will see voltage.
Old 05-05-2015, 10:38 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well.... what was the 'problem'?
Peace and Blessings..
Channing
WBCCI# 30676
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
help dead short pk63 Batteries, Univolts, Converters & Inverters 6 05-29-2002 08:56 AM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
