Old 12-18-2004, 02:09 PM   #1
Unhappy Dead doorbell
The doorbell gave up in my Excella 1000. Does anybody know where the actual unit is located?
Thanks.
zracz is offline   Reply With Quote
Old 12-18-2004, 03:05 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
You have a doorbell I guess those 34'ers are so big you might not hear someone knocking if you were in the back
Welcome to the forum!
Stephanie
Old 12-18-2004, 03:16 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
under the sofa on the street side. too bad it isn't working so you could ring it to find it!
kinda like when i loose my pager and have to page myself to find it!
john
you call them ferrets, i call them weasels.
Old 12-18-2004, 03:26 PM   #4
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Dead as a door bell?
I thought it was a door nail.
Sorry Zracz, I couldn't resist...
But welcome to the forums.
Jerry
Ultradog is offline   Reply With Quote
Old 12-19-2004, 06:24 AM   #5
baldeagle's Avatar
Smile doorbell
In our 1984 excella 31' it was under the front lounge on the curb side. Could be seen by removing the under lounge drawer.
Hope this helps
PATHWAYS Guys
baldeagle is offline   Reply With Quote
Old 12-19-2004, 06:37 AM   #6
Craftsman
Guest
Posts: n/a
Talking
I guess knocking might dent the door
Old 12-19-2004, 08:14 AM   #7
Thank you all.
Old 12-19-2004, 08:19 AM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
you will most likely find the button is bad.
if you have a replacement from airstream you can basicly rip it out with a needlenose pliers and replace it with the new one. it snaps into place from the outside.
for a less destructive method you will need to remove the inner skin next to the door and push the button out from the inside.
before you try anything give the button a shot of wd 40 and see if it starts working again. it may just be slightly corroded.
john
Old 06-09-2019, 12:06 PM   #9
GUELPH , MB
john
This is helpful. Do you just pull it right out?
passenger56 is offline   Reply With Quote
Doorbell Craig 1978 Excella 30 09-10-2017 11:37 AM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
dead bolt joel Doors & Locks 1 08-25-2002 08:35 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
