Old 07-31-2010, 09:37 AM   #1
tdveal's Avatar
1972 29' Ambassador
Sherwood , Oregon
DC doesn't work in Front section, only??
Hi, My 1972 Ambassador has a DC problem in that the control panel, reading lights and the hitch motor only works when the trailer is connected to the tow vehicle. This is true even with AC hooked up.
Any suggestions would be appreciated.
Best regards,
tdveal is offline   Reply With Quote
Old 07-31-2010, 09:47 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sounds like a blown fuse on the DC distribution panel. It should be on or near your converter.
Richard
Old 07-31-2010, 10:06 AM   #3
tdveal's Avatar
1972 29' Ambassador
Sherwood , Oregon
Is the Coverter the Box where AC comes in. It has two circuit breakers which I've cycled several times.. I see a 'circuit breaker' in the DC Schematic that is between the tow connector and the control panel.
Old 07-31-2010, 01:07 PM   #4
2002 25' Safari
Dewey , Arizona
Images: 62
The box you are seeing is for the shore power (120 volts). The converter converts 120 volts AC to 12 volts DC. If yours is the original it is a UniVolt and it most likely hums when the trailer is connected to shore power. Mine is in a closet in the bathroom and I would suspect that yours would be somewhere in the bathroom area as well. The 12 volt distribution panel will either be attached to the unit or somewhere else close by. All of the 12 volt circuits attach to this panel and each has a fuse. This is mine:
Richard
Old 07-31-2010, 02:37 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
When I lost power in 1/2 of my 70 globetrotter it turned out to be a large wirenut splice in the ceiling . This required pulling the ceiling center panel so save this solution for last, after all else fails
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
electrical system
Section an Airstream?? Anyone done this?? amoretti Exterior Restoration Forum 6 02-14-2010 10:23 AM
Front Pano tinted RG section is .... SilverToy Windows & Screens 0 03-29-2006 01:05 AM
Front ducting work Mobile1 Classic Motorhomes 1 11-16-2005 01:27 PM
exterior work at front end mlmarch Airstream Motorhome Forums 4 05-04-2003 07:25 AM
