Old 12-11-2019, 06:47 AM   #1
Nick
2020 28' Flying Cloud
Question Current draw of airstream connect
Does anyone have information on the current draw of the pepwave router used in Airstream connect. It is wired direct and on 24/7 and we are curious about battery drain while boondocking.
coblio is offline   Reply With Quote
Old 12-11-2019, 07:09 AM   #2
2019 25' International
Providence , Rhode Island
Looks like maximum of 12 Watts
File Type: pdf pepwave_max_br1_mini_LTE_datasheet.pdf (806.1 KB, 3 views)
kittmaster is offline   Reply With Quote
Old 12-11-2019, 07:19 AM   #3
2018 25' International
Slidell , Louisiana
For a ballpark number, Online sources indicate WiFi routers consume between 2 and 20 Watts. Peplink has data sheets for all of their products. You didn't say but I'm assuming it's a Surf On The Go model and if so they say "5 Watts Max" . Here is the link https://download.peplink.com/resourc..._Datasheet.pdf
Brian
Old 12-11-2019, 07:58 AM   #4
AS connect uses the model I attached the datasheet for. So your link will not help him.
Old 12-11-2019, 08:09 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Based on other similar systems, an amp draw is a pretty good bet once WiFi and Cellular are in the mix.
Old 12-11-2019, 12:17 PM   #6
2020 30' Classic
Blue Ridge , Georgia
Mine has a key off and on switch. Does it have a draw when turned off?
Gleverett is offline   Reply With Quote
Old 12-11-2019, 12:25 PM   #7
If it it's the BR mini unit, when off, there should be no 12v to it, and therefore, no current draw i.e. no power draw.
Old 12-13-2019, 08:23 AM   #8
Nick
Current draw on airstream connect router
Thanks, that is the model I have so thank you for the information. While it does not seem like much, I figure it is about a 1 amp draw (watts/voltage) so hopefully my solar panels will keep the batteries charged while boon docking. The power connect is a bear to get at so a switch may be indicated.
Thanks again.
Old 12-14-2019, 06:59 AM   #9
Half a Rivet Short
Hi
1A for 24 hours gets you 24 AH. On a cloudy day or three (it's been raining here ...) that can be a pretty big deal.
Old 12-14-2019, 10:02 AM   #10
stevejones's Avatar
2019 27' Globetrotter
Martinsburg , West Virginia
The datasheet for the Pepwave modem/router used in AS Connected says Power Consumption: 12W Max. The antenna is passive.
If you use a second router as many do, be sure to include the power consumption for that as well.
If your AS Connected system does not have a power switch for the Pepwave router, you should add one inline with the 12VDC supply. That way you can turn off when trailer is not being used, or easily reboot the router.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
stevejones is offline   Reply With Quote
Old 12-14-2019, 11:06 AM   #11
2019 Nest
Austin Area , Texas
FWIW it is pretty easy to measure the amp draw across the 12v fuse which supplies power to any item. You simply pull the appropriate fuse and connect a multi-meter (most can measure up to 10 amps at 12v) where the fuse was.
Itís best if you turn off as much 12v stuff as you can prior to pulling the fuse. If your AS doesnít have a label telling you what each fuse handles, this would be a good opportunity to fix that
BeSerious is offline   Reply With Quote
Old 12-14-2019, 04:47 PM   #12
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Gray Court , South Carolina
Thanks but that is not the right model.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 12-14-2019, 04:48 PM   #13
The Silver TARDIS
2018 30' Classic
Agreed. You posted the correct model.
Kevin Short
BlueOx SwayPro 1506
Old 12-17-2019, 01:07 PM   #14
1977 31' Sovereign
Victoria , British Columbia
AC to DC draw?
Most of these types of routers draw AC and convert to DC. If there is a DC draw at 12V it will indicated on the AC converter you plug into the unit. That is the best indication for watts provided at 12VDC you can find. My Netgear 4G LTE modem draws 12 V at 1.5amps. My Linksys 1200 WIFI router draws 12V at 1.5amps. I have them on a switch so I can turn them together on and off.
5-7amps at 12V is a lot of power. My fridge only draws 2.4 amps at 24V - I would check your work on the 5-7 amps at 12V.
The other side of the coin is to make sure you have a battery bank for boondocking that can make it through a couple cloudy days. You will need 200AH or more at 12V. I have a 800W of solar and 200AH of batteries at 24V and it may not be enough sometimes.
Kristof
Kristof is offline   Reply With Quote
Old 12-17-2019, 02:33 PM   #15
Kristof
I don't know what you are talking about.......there is NO AC component to this unit. It is wired right to 12VDC. The unit can draw at most up to 12W thereby pulling about 1 Amp of current worse case.
In a short term, it is not much of a draw, but over a long period of time and on a cloudy day, it can wear down the batteries if not recharged by an external power source.
How Would You Connect This Inside the Airstream? centennialman Audio, Video & TV 9 12-14-2016 06:47 AM
Current draw question davidz71 Lights - Interior & Exterior 12 02-04-2008 08:49 PM
Shorten Draw Bar? dmac Hitches, Couplers & Balls 10 10-23-2003 01:35 PM
A/C Current Draw Pick Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-03-2003 08:36 PM
BBBBRRRRRRRLOW Serious voltage draw Phaedrus Generators & Solar Power 1 06-15-2003 11:09 PM
