Old 04-02-2016, 08:06 PM   #1
TXMYTX's Avatar
2009 27' FB International
Rio Medina , Texas
Cube heater and Electric Blanket Not Working
STRANGE! Everything works, including furnace, air, lights, refrigerator ...expect for my cube heater, electric blanket, and microwave (when using generator, or shore...No problem for the last 6 yrs)...I have a 2008 International. No blown fuses...Any ideas?
TXMYTX is offline   Reply With Quote
Old 04-02-2016, 08:08 PM   #2
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
have you checked outlet for voltage. ?? that is strange indeed.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-02-2016, 08:34 PM   #3
TXMYTX's Avatar
Rio Medina , Texas
One other thing...The microwave blow the other night during a storm...Could that have created a problem...
Old 04-02-2016, 08:35 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Find your AC breaker panel and check the breakers. AC operated devices are on a separate panel with circuit breakers like your house, not fuses.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-02-2016, 08:36 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
First, you should be checking the breakers in the 120v panel, not fuses.
Are all of the 120v things you mention on one circuit? If they are, I'm guessing you have a bad breaker or a broken wire.
I would plug in the cube and blanket directly into the generator to make sure nothing is wrong with them.
Absolutely! Anything in the trailer could be damaged.
My 34' took a lightning surge last summer. First the AC went after a few hours (fan motor went out), the power cord end went out after a week (shorted the plugs internal parts), then I found a battery had shorted internally. Lightning can do some strange things. It cost me close to $1,000 in material to make the repairs. I made the repairs myself, so there was no labor cost.
At first I did not realize the lightning had cause the damage, not until I looked at the power cord and saw it had partially melted.
A W Warn is online now   Reply With Quote
Old 04-03-2016, 03:01 PM   #6
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Isn't the conventional wisdom to pull the power plug during a thunder storm?
I learned that several years ago, when a Lightning storm blew my surge protector out.
The thing died doing it's job of protecting my Hi-Lo. 'Cost me $165 for a new surge protector; much better than several thousand for new wiring.
MelGoddard is offline   Reply With Quote
Old 04-03-2016, 03:26 PM   #7
Long Island , New York
Al
Did you check the AC circuit breakers as detailed in the owner's manual?
Old 04-03-2016, 05:41 PM   #8
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
On my 2009 classic I found a couple of loose wire nuts. Wire nuts are not designed for automotive use. The vibration causes them to become loose, even when installed properly. Crimp terminal are designed for automotive use if installed with the proper tool. Just a thought that you have a loose connection someplace. Good Hunting.
gr.austin is offline   Reply With Quote
Old 04-03-2016, 05:49 PM   #9
Make sure electricity is off when you check out the 110 volt AC wire nuts!
Old 04-03-2016, 07:42 PM   #10
1973 31' Sovereign
Middletown , California
It could be that the microwave and heater are on the same breaker along with the outlet that the blanket is plugged into. Turn off the breaker all the way and back on and see if that fixes it. My older Airstream only has 2 breakers for the whole trailer, 1 for the AC and 1 for everything else. Can't run heater and microwave at the same time. In fact when using an adapter on the 30 amp plug to a regular 15 amp outlet or extension cord I can melt the adapter by trying to run 2 heavy loads at the same time. I call trailer living "life on an extension cord"! I usually end up with several cords feeding my trailer depending on how I'm getting power. More power = better living for me!
ijustlee is offline   Reply With Quote
Old 04-03-2016, 08:15 PM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
get one of the little AC outlet testers with the led lights and check the outlets. the tester is a good thing to carry in the trailer. Check the breakers in the box. You do have to turn it all the way off and then back on. most likely a tripped breaker. the refigerator and the lights and the furnace work on the 12 volts. On our older trailer there is a switch that switches power between the AC and the microwave. Do you have that switch? I guess not if it has all been working at the same time all along.
Bill M. is online now   Reply With Quote
Blanket UNDER mattress HCR 2006 Safari SE 20 11-18-2010 02:40 PM
electric blanket? janiemerle Furnaces, Heaters, Fireplaces & Air Conditioning 9 02-15-2010 06:33 AM
Vu Cube 99Limited34 Computers, Internet & Satellite 8 06-05-2009 01:10 PM
Solution for blanket hogs Happycampers Off Topic Forum 1 09-21-2007 08:05 AM
towing with a 16' box truck (cube van) MrSalt Tow Vehicles 10 09-07-2005 09:24 AM
