Hi
What you can "feel" and what is hazardous are two *very* different things. Under any normal conditions, low voltage DC can't produce enough current for you to feel. What it takes to injure you is orders of magnitude higher than the "I can feel it" point.
Walk across the right kind of carpet in the winter and you will generate enough charge for a "shock" that you can feel. That happens a lot. If being able to feel the shock was the same as injury, we all wold not have made it past about age 5 or 6.
Indeed if you have a pacemaker or other interesting implants, electrical work it not a real good idea. Let somebody else do those chores .... also probably a good idea to avoid that carpet....
