Old 08-12-2018, 10:01 AM   #1
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
crimping and wire termination items
here is what i used to terminate all wires.
i also place a drop of anti oxidant on the wires.
this why i know i will get maximum wire contact and keeps all fray wires in check. each ferrule is made for a specific wire size
here also is my crimper for spade and inline connectors
Name:	wire connectors2.jpg
waninae39 is online now   Reply With Quote
Old 08-12-2018, 10:09 AM   #2
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Crimpers and Connectors...
Nice setup! Find it all in one place or did you put it together yourself?
Tom - Slide-Out Society Registry Member #025
AlumaSlider Get-Together, 28-30 Sep 2018, Stone Mountain SP, NC
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 08-12-2018, 10:40 AM   #3
Zil
egg harbor city , South Jersey
That is a nice setup. Here is plenty of information about wire termination by a recognized expert. He also has a separate one for battery cable terminations.
https://marinehowto.com/marine-wire-termination/
You can read Rod Colin's introduction here; https://marinehowto.com/about/
Zil is offline   Reply With Quote
Old 08-12-2018, 10:44 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
...On using all 'marine'. 👍
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 08-12-2018, 12:46 PM   #5
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
the red handle goes with all the different AWG tips. i did not show the anti oxidant paste as that can be found anywhere
the yellow handle goes with the different crimper heads above it
all came from amazon. cheaper that local box stores
Old 08-12-2018, 02:47 PM   #6
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Take it from someone who makes a living with a crimp tool. ( live and die by one) the Goal with any good crimp tool is to provide Side support during the crimping process and the crimp tool should not release the crimp till it has made a full crimping cycle. The one listed below does these things
https://www.google.com/shopping/prod...aWkD-AQgTYIyAQ
Old 08-13-2018, 09:06 AM   #7
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 68
Nicely done
You made good choices.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is online now   Reply With Quote
Old 08-13-2018, 10:33 AM   #8
2018 30' Flying Cloud
Gig Harbor , Washington
I added to my kit a heavy duty crimper, various shrink covers and a heat gun to shrink the covers.
Your kit looks good!
hoagy_007 is offline   Reply With Quote
Old 08-13-2018, 03:15 PM   #9
1987 34.5' Airstream 345
Auckland , New Zealand
Do your self a favour for the future
For a trouble free electric future,
use copper conectors not soft alloys then crimp and solder then heat shrink with a dab off carbon grease on the mating surfaces for excelent conductivity switches as well. Dont run the solder up the flexable part off the wire thoe..keep that part max flexable.
If your planing flicking on your modern trailer that has been bounced a shaken and shudded down the road to some other poor sucker then good for you!
Or you will be forever wobbling with your old wires.
Do it once do it right! Even If not for your self.
Voltair is offline   Reply With Quote
Old 08-13-2018, 03:28 PM   #10
2007 22' International CCD
As a LONG time electronic engineering type, ham radio operator, and Boeing retiree, soldering an already gas-tight crimp connection is a total waste of time, and only increases the possibility that the wire may be 'work hardened' due to the stiffening effect of the solder wicking into the wire strands. It's darn near impossible to prevent solder from going where you don't want it to go.
Properly made, crimped connections with decent Marine or Aerospace rated connectors, a ratchet crimper, and properly sized and insulated stranded wire are the most reliable. A nice adhesive-lined shrink tubing is a nice add-on if the connections might get moisture exposure.
Soldering is no longer the best way to go.
rmkrum is online now   Reply With Quote
Old 08-13-2018, 03:52 PM   #11
X2
...no solder on marine or AS.
RLC
RLC
"Tahawus"
Old 08-14-2018, 07:16 AM   #12
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
I just use the stinger and socket of my Pro Pride hitch .
Thanks for giving me a whole 'nother box of tools and stuff to buy for me and the next guy.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 08-14-2018, 12:33 PM   #13
Isn’t it a basic law of the universe that another project taken on requires at least one new tool and three trips to the big box home improvement store to get all the right components?
Seems to be true in my corner of the universe
Old 08-16-2018, 06:22 AM   #14
Obviously-NOT
Kalispell , Montana
Law? I thought it was, "New Project" was a coupon and budget line item for, "new tool(s), new carry bag, enough consumables to re-do a rally's worth of issues".
Why I bought the 1-ton .
Battery Cable Crimping Tool Help noleander Batteries, Univolts, Converters & Inverters 71 04-02-2018 05:41 AM
PEX what crimping techniques work best perryg114 Plumbing - Systems & Fixtures 24 09-28-2011 08:09 PM
pex crimping rama777 Fresh Water Systems 5 10-28-2006 04:44 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
