Old 05-27-2016, 04:16 PM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Cracked Shore Power Cord - Repairable ????
The locking ring on the Furrion shore power cord on our 2014 23D is cracked and essentially worthless. Two questions:
1. Can the locking ring be replaced?
2. If so, how in the world? It looks impossible.
Rob (who searched to no avail!)
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 05-27-2016, 04:20 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The locking ring is easily replaceable, and not expensive.
http://furrion.com/product/plugs-and...cement-ring-2/
Old 05-27-2016, 04:30 PM   #3
RFP
RFP's Avatar
Hurst , Texas
Thanks a million, Terry...
But, I guess that I'm not very bright... I can't figure how one gets the danged thing onto the plug. It would seem to have to go over the very annular rim that it bears against when locking.
And some stuff
Old 05-27-2016, 04:33 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
A little vaseline or white grease makes getting a new ring on the cord easier.
Old 05-27-2016, 04:49 PM   #5
Long Island , New York
Are you saying that the new ring has to be slipped over the opposite end of the cord, worked up to the trailer end, and that the grease will enable working the ring over the raised retaining ridge around the weather cover (grey in our FC20)? I guess it is rubber, and flexible to a degree, but on ours I can't picture being able to get the OEM ring off, by doing the above backwards FWIW. Perhaps the new replacement ring has a larger interior diameter?
A call to Furrion might be worthwhile IMO.
Old 05-27-2016, 05:20 PM   #6
RFP
RFP's Avatar
Hurst , Texas
OK, I'm probably a little dense, but I think I've got this figured out(!) The rear opening of the locking ring is heavily chamfered, and the 'plug' is made from a somewhat flexible material. So, the old ring is either broken off or cut off and the new ring is just 'lubed up' and forced over the annular rib. Ta da!
How'd I do?
Rob
And some stuff
Old 05-27-2016, 05:33 PM   #7
How'd I do?
Rob
That is what I just asked switz to confirm, starting with your new ring at the opposite end of the cord, where the male plug end is.
Good luck!
Peter
Old 05-27-2016, 05:53 PM   #8
RFP
RFP's Avatar
Hurst , Texas
Good luck!
Peter
Peter, I see what you are saying. But, I'm thinking that may not be the magic formula since that way you would be working against the 'step' of the flat part of the locking ring instead of benefiting from the chamfered side. This just can't be as hard as my mind is making it. Of course, my wife would tell you that I can complicate absolutely anything.
And some stuff
Old 05-27-2016, 05:57 PM   #9
Will wait for switz's feedback. By the way welcome to the forum!
Peter
Old 05-27-2016, 06:58 PM   #10
RFP
RFP's Avatar
Hurst , Texas
Peter
Thank you, Peter, for your kind welcome... I'm grateful for the Forum and the willingness to help - and friendliness - of the many members.
'Switz' gave me great guidance as I changed my 14" wheels/tires to fifteens on our 23D. It was a godsend to get help from somebody who had already been down that path.
Rob
And some stuff
Old 05-28-2016, 07:50 AM   #11
switz's Avatar
2014 31' Classic
Images: 8
At the end of the power cord where the broken ring is, break off the cracked one. Put some non-petroleum lube on the retaining rib and work the new ring on. Have had to do it with spit in a pinch. You are installing over the end of the plug, not coming from the other end of the cord.
I also carry the Furrion union as I have a second Furrion cord with twist-lok connectors on each end. One end can attach to the trailer as normal and the other plugs directly into the twist-lok connector on one of my Honda 2000 watt generators. With the union, I can create a much longer power cord. I think one is 25' and the other is 30' so together they are around 55' which is probably about as far as one wants to go to preclude voltage drop if the air conditioner and other "stuff" are running at the same time.
Sharing our experiences, both good and bad, helps everyone else. No need to create the wheel for each of us if some one else shares how they did it. Also sharing why what one tried did not work is very informative.
Old 05-28-2016, 10:23 AM   #12
Thanks -- on our plug that looks like that operation would be difficult to do with the OEM ring. Hopefully we'll never have to try!
Assuming your OEM charging cords are #10 AWG, your combined 55' is stretching it with A/C use IMO, but you appreciate that, I know. For the twist-lock 30A 120 volt outlet on our Honda 3500 gen, I just got a short adapter which turns the twist into the standard 30A welder's plug outlet FYI, which "regularizes" things away from the twist world.
Thank you for your previous advice on many diverse subjects, especially tires and wheels.
Have a good long weekend.
Peter
Old 05-28-2016, 01:40 PM   #13
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
A warm, flexible retaining rib laying in the sun will help also.
Howard L. is offline   Reply With Quote
Old 05-28-2016, 02:44 PM   #14
HoffmanP's Avatar
2014 27' FB International
Prospect , Virginia
Or, just use black electric tape to fix the broken ring. I did that and later bought the replacement ring, but it still sits in my tool box.
Paul Hoffman
2014 27FB International (WBCCI # 5327)
VA Plate: SOJOUNR
2013 Ford F-150 XLT Super Cab (Silver)
VA Plate: TRL DUST
HoffmanP is offline   Reply With Quote
Shore power cord replacement atvmcg Electrical - Systems, Generators, Batteries & Solar 7 03-21-2017 05:55 AM
shore power cord and 12 volt. jpalm1048 Electrical - Systems, Generators, Batteries & Solar 2 09-07-2010 10:46 AM
Trying to replace shore power cord tlavergne Electrical - Systems, Generators, Batteries & Solar 6 08-13-2010 08:51 PM
Shore Power Cord Reel wasagachris Batteries, Univolts, Converters & Inverters 2 06-16-2010 11:28 PM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
