Old 05-28-2016, 04:19 PM   #15
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
boil a pot of water, when water is boiling real good drop ring in and let it sit at a boil for a minute, the ring will soften a bit from the heat, then use lube and gently slip on
PeterKV is offline   Reply With Quote
Old 05-28-2016, 07:42 PM   #16
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Originally Posted by switz View Post
I also carry the Furrion union as I have a second Furrion cord with twist-lok connectors on each end.
+1 for an extension cord with twist-lok connectors on each end (technically a NEMA L5-30 connector). Note, it does not have to be a Furion brand. These extensions are common in marine applications, so look there, as well. My extension happens to be yellow and is made by Marinco.
As switz said, by adding a union (basically a double ended threaded sleeve), the connection between your usual power cord and the extension can be made water resistant.
Greg
greghoro is offline   Reply With Quote
Old 05-29-2016, 08:13 AM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I added a power inlet to our 2015 23D International Serenity in front with a real transfer switch with contacts. (really cheap of Airstream to not put one at least on the International trim line of the 23' models for the multi thousand dollar price differential).
The Honda 2000 watt generator gets it's propane from the front outlet on the "A" frame. I made a six foot #10 cord with Furrion twist-lok fittings to go from the one generator with the twist-lok fitting to the trailer. If the second generator is added, then the full 30 amps would be available with a external propane tank for the second generator.
switz is online now   Reply With Quote
Shore power cord replacement atvmcg Electrical - Systems, Generators, Batteries & Solar 7 03-21-2017 05:55 AM
shore power cord and 12 volt. jpalm1048 Electrical - Systems, Generators, Batteries & Solar 2 09-07-2010 10:46 AM
Trying to replace shore power cord tlavergne Electrical - Systems, Generators, Batteries & Solar 6 08-13-2010 08:51 PM
Shore Power Cord Reel wasagachris Batteries, Univolts, Converters & Inverters 2 06-16-2010 11:28 PM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
