Old 09-15-2002, 03:04 PM   #1
Ann Arbor
cover for univolt
The univolt in my '77 Sovereign does not have a cover over it. I assume that it did when it was new because there is a sort of frame around it. I am a bit concerned about having the various electrical connections uncovered in case of contact with cloth or other material that might be tossed (or fall) behind the goucho. So I have two questions. First, would a sheet of plexiglass cut to fit be an appropriate cover? Second, do I need to worry about heat build-up behind any cover I put over the univolt.
Thanks for your advice.
Eugenie
maznblu is offline   Reply With Quote
Old 09-15-2002, 04:36 PM   #2
LOST , Hawaii
You can use plexiglass, but it must have relatively small holes for ventilation (small enough to keep it free from foreign objects, large enough to cool). For the same reason the area around it should be kept clear.
John
74Argosy24MH is offline   Reply With Quote
Old 09-15-2002, 07:02 PM   #3
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Plexiglas would look cool, but...the reason it is metal covered is to contain sparks and flames. I have opened power supplies and circuit breaker boxes before and the only thing that contained the flames was the metal covering. Same reason construction codes require metal plates over junction boxes in residential wiring. Your uncovered, exposed Univolt is extremely hazardous.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
? about the hinged rear bumper cover Bryanhu Bumpers & Bumper Storage 4 04-21-2017 08:25 PM
Propane Tank Cover tmeagle1 LP Gas, Piping, Tanks & Regulators 6 03-04-2004 07:30 PM
Toilet seat cover overlander76 Sinks, Showers & Toilets 6 07-27-2003 10:50 PM
Vintage Oval Shaped LP Tank Cover smily LP Gas, Piping, Tanks & Regulators 3 12-20-2002 04:52 PM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
