Old 06-13-2007, 02:00 PM   #1
2007 25' International CCD
New York , NY
cost of 50 amp installation
Hi -
Our company operates a custom made 25' International at various sites across the country. The trailer is outfitted with one 50 amp service, of which we draw over 30 amp to run the HVAC system plus electronics.
We have encountered a number of situations where a site has to install a 50 amp service as there is not a pre-existing one. Does anyone have a guess as to what a typical cost for an on site installation of a 50 amp service might be?
Thanks!
Ryan
Armur is offline   Reply With Quote
Old 06-13-2007, 03:33 PM   #2
GLASS GODDESS
2011 22' Sport
Greenville , South Carolina
Hi, I spoke to an electrician about up our amps from 30 to 50...it the guage on your trailer is heavy enough to carry the additional amps and your inverter can handle the additional load, then all it takes is the breaker to be replaced and the fuses upgraded. Unfortunately, although we have a powerful inverter, in order to upgrade, we would have to rewire everything with a heavier guage.....hope that helps.
Dureedesign is offline   Reply With Quote
Old 06-13-2007, 04:47 PM   #3
Images: 59
There are way too many variables. Think in terms of $1500 to $2500. If there is a welding socket nearby it would be cheaper.
In Manhattan it might cost $5000.
Old 06-13-2007, 04:50 PM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
If you are talking about installing a standard 50 amp RV service, you are talking about the cost of two 50 amp breakers, four conductor wire of sufficient gauge to carry 50 amps for a run from the panel to the outlet location, the cost of the 50 amp receptacle and a box to mount it in. Plus labor. This assumes that you breaker box has room and capacity for the two new 50 amp breakers
When I had mine put in I had a bunch of other work done at the same time so I can't say what the cost for just the 50 amp service was.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 06-13-2007, 06:12 PM   #5
crowbar68's Avatar
1975 27' Overlander
fort wayne , Indiana
i would say around 1000 min w/ labor and material. copper is way up and depending on were you get pwr may need to upsize wire if in conduit etc. especially if commercial property.
" If everything is working, something is wrong ! "
crowbar68 is offline   Reply With Quote
Old 06-13-2007, 06:25 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
ARMUR
If you are talking about a commerical trade trailer used to display your companies goods it would be far more cost effective to buy a generator and have it installed in the trailer or tow vehical. The numbers quoted above are conservative.
2004 Excursion 4x4
Old 06-13-2007, 06:45 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
There are breakers or fuses. Not both
A true 50 amp RV service can not safely be had from an existing 30 amp service. A true 50 amp RV service is a 240 vac service (120 vac on each leg) which is realized through four wires - Two hots, a neutral, and ground. A 30 amp service has one hot wire, a neutral, and a ground for three wires total.
Many factors play into a true 50 amp service with the length of the run being primary. Figure $3-$4/foot for the wire (anywhere in the U.S). $60 for the outlet/service box to plug in to, $50-$100 for breaker at service panel & misc. fittings, $100 - $300 for trenching (if required), $100/hour for the electrician for probably a half day's (minimum, in his opinion) effort.
Tom
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
30 amp box davidz71 Electrical - Systems, Generators, Batteries & Solar 10 10-23-2005 09:38 AM
Installation Rally Pahaska WBCCI Rallies & Events 5 11-20-2002 09:38 AM
