Old 02-10-2004, 06:08 PM   #1
till's Avatar
Lisle , Illinois
Images: 108
Exclamation Copper and aluminum?!?!!?
In looking at my wiring as I have been cleaning out the non-Airstream stuff I have noticed that the 12VDC wire is aluminum and the 110VAC stuff is copper. This seems very wierd. Is this normal for the year of production? It is a Califonia built trailer, for what it is worth, could it be a West Cost thing. I am glad to see the copper for the 110 plus this will make it easier to figure out what is what.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 02-10-2004, 10:01 PM   #2
RivetED's Avatar
North Central , USA
Check to be sure it's aluminum, It may be 'tinned' copper strands. Scrape a bare spot or look at a cut end.
RivetED is offline   Reply With Quote
Old 02-10-2004, 10:59 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
don't panic
tedd
aluminum wire was popular during the period your trailer was built, other members have reported it in trailers from the same era.
just remember to make sure connections are clean and tight, adding an inhibitor to connections is an absoulute must! it can be had at most home centers and good hardware stores. no-ox, penatrox are a few brand names.
keep an eye out for discolored connections, a wire brush will help cleaning them up.
power utilities install millions of feet of aluminum wire a year with good service. aluminum wire is NOT a product of satan, just seems that way when a outlet quits working!
john
you call them ferrets, i call them weasels.
Old 02-11-2004, 06:17 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Wait...there's more Al
My '67 Overlander also uses solid aluminum wiring for the heater, and A/C thermostat wiring.
Old 02-11-2004, 07:39 AM   #5
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
wiring
My '67 has the alum. wiring as well. There's some websites you can find with a search that outlines the caution to be taken with the alum. Agree with the previous poster, you should check all of your connections to make sure they are clean and not increasing resistance and then heat. The websites you'll find also have pics on how to do simple copper/alum. pigtails to your outlets and lights to reduce the chance for a problem.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
